Question about Kyocera Mita FS-1920 Laser Printer
Kyocera fs1920 problem
I have a kyocera fs 1920 and it say call for service F030
  • 2 more comments
  • chippenham1 Nov 19, 2008
    I have an error showing on my Kyocera FS1920 saying F030:0054087 can anyone give me a solution? If I turn the printer off and on again the status pages will print fine but when I send information to it via my computer the error message comes back up. Thanks
  • Pman Dave Feb 16, 2009
    I get the F030 error and can not find the firmware upgrade for my Kyocera FS 1920
  • Anonymous Mar 02, 2009
    My printer display a message that indicates on screen: Call service F030:0024282, when you switch it off it goes away, and trying to print again. same message. The printer is connected via a usb cable. Please help
  • Anonymous Mar 20, 2014
    call service 1010:0000020
  • 43 Answers
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Posted on Dec 16, 2008
Fs 1920 service 1200
your du-61 duplex unit is faulty or not installed correctly check the harness and gates if all this is ok its the engine pwb has failed
Feb 17, 2014 | Kyocera Mita Office Equipment & Supplies
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Jun 22, 2012 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920, error F030:0077538
i've been working on kyocera's for about 4 years. now..this error is not good..it's a general system failure..only solution is replacing main board.
contact me if you need a part #.. I can look it up for you
Feb 01, 2010 | Kyocera Mita FS-1920 Laser Printer
Call service engineer Kyocera
power down unit and power on... if same error get a surge protector or power conditioner... plug unit into it and then power down and power up... if same error replace the memory card in the unit... if same error replace memory board...
Apr 10, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera FS-3830 with error F030
Try www.kyocera.com and look around for links to software upgrades.
Nov 30, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Change cartridge's instrutions for kyocera FS1920
Hi
To replace the toner in the Kyo fs 1920 you have to open the top cover, under you will se a small blue clip in the upper right section, you have to pull that to the right, it will release the the toner box what is the big black pice under the to cover. After removing the toner box place the new toner box in the right direction (if you are in front of the printer, you can read the text on the top of it) and push it gently down. You should hear a click and you can see the movement of the light blue clip. Ps.: don't forget to remove the orange pieces from the new toner box befor installing.
Aug 18, 2008 | Kyocera Mita FS-1920 Laser Printer
Call Service issue
Hi sunny82 ,
I think You have defective laser unit,but first try to clean it.
Sep 23, 2007 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
1,602 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
NewYork kyocera HP...
Henry Gertcher
Soulvisitor
Soulvisitor
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
