Question about LeapFrog Toys
Touchscreen doesn't work
The touch screen doesn't work with stylus.
  • gmcrkrjr Nov 09, 2008
    Actually, I took the back cover off and found that the plug for the touch screen came unplugged. This was given to me and has been used by an 8 year old so it probably got banged around. I put a dab of silicon sealer on top of cable and connector so it won't happen again. Thank you for your reply.
    Problem Solver:
  • 8 Answers
I just got one too and u have to do it head on hard or  it wont work
Posted on Nov 09, 2008
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Stylus does not work on touchscreen
Did you manually cancelled the touch screen support or locked the screen if not hurry for repair shop coz may be serious problem with touch screen
Nov 09, 2010 | Sharp Wizard OZ-290
Touch screen not working
First thing you have mentioned you are using Nokia 70 which dont have the touch screen feature....
If your phone is not recognising the stylus completely, it means your touch screen is malfunctioning or it is broken from inside... you need to get the touchscreen changed.... i will not suggest you to change it your self as touch screen is very deligated....
Jul 09, 2009 | Nokia N70 Cellular Phone
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Touch screen is out of sync, can only use the manual control
Go to Preferences. Select touchscreen. Then follow the instructions for the screen calibration program.
Oct 26, 2008 | Palm TX Handheld
HP problem with touchscreen Hello, did you solve your problem with touchscreen. I've had the same problem yesterday. could you help me please? thanks.
When you first begin using the PC, or if you have intermittent problems using the touch screen, you should calibrate the touch screen and set up the screen preferences.
NOTE: The touch screen works best if only the stylus, and not your hand, is touching the screen. If you rest the palm of your hand on the screen for comfort, you will have to press the pen more firmly onto the screen.
Mar 15, 2008 | Computers & Internet
Touch screen
Haha I love the Centro. You need to perform a system reset to the phone the directions are in your manual. Basically, the touch screen is screwed and by reseting it and following the prompts that should resolve your issue. You don't lose any information either so you have nothing to lose.
Nov 09, 2007 | Palm Treo 680 Smartphone
Treo 600
That means your touchscreen is no-good at all. I had the same problem. Had to get a rebuilt 600 from Sprint (thank god for the insurance plan).
May 23, 2007 | Palm Treo 600 Handheld
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
Toys Logo
320 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
