Question about Sony Playstation 3 (PS3) Console
"can not start. correct hard disk not found" screen message
System starts, music, wavy band and then screen message. I've removed and re-seated the hard drive but did not resolve the problem. Can the hard drive be re-formated if switched out in another 80 gig PS3?
  • Anonymous May 15, 2009
    Same problem here.
    ps3 instructs that it cannot start cannot find hard-drive disc
  • 95 Answers
Well you may have a bad connection at the SATA port. this happens alot cuz of the heat generated by the CELL CPU (adjacent to the SATA PORT) . either this or your harddrive has failed
Posted on Nov 11, 2008
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Ps3 slimline says cannot start the correct hard disk was not found
Dear Friend,
Have you consider to replace your hard drive?. That might be a good possibility why your PS3 can not start the way it should. Try that and see what happens.
Good Luck!
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Message on screen: Windows failed to start. A recent hardware... It then cuts to startup repair and attempting repairs. Have gone through this a dozen times only to end up where I started. What do I...
I assume you've already tried pressing F8 on startup to get into the start-up options screen (from there you can attempt "Restore System to a previous date.").
If you can't get anywhere with the F8 options, try starting up your system from a Windows Install disk. (Unfortunately, few computers come with this. Some have a Restore mode using either a special startup hot key or a set of optical disks, but this usually involves formatting C: and wiping out everything before setting it back to factory original state.) Once you have the Windows Install disk going, watch for the Automatic System Repair option to come up. This is different for each version of Windows, so I can't give you more than that other than to follow the on-screen instructions.
Note: virus infections can disrupt the hardware registry and produce the symptoms you have. By now, your backup registry is corrupted (that is why the automatic repair fails). I've found the easiest virus fix for a desktop computer is to remove the hard drive and install it as a second drive in a known-good computer, then have that system scan the problem drive for virus infections and file system corruption. If you have a 2.5" - 3.5" drive adapter and can remove the drive easily, you can also use this tactic on laptop hard drives. You will probably still need to repair the operating system damage.
Nov 14, 2011 | Computers & Internet
My HP 4710s had a weird message that pops up after the logo screen. Then it says non disk or disk error strike any key to continue...I do that and the same message pops up...plz help.
the HP cannot boot up because it cannot find the hard disk to boot up from.
You could have a faulty hard drive or the hard drive needs re-seating.
If the HP still does not boot up after re-seating the hard drive go into the BIOS setting and see if the hard disk is detected. If not the most likely the hard disk is faulty.
To get the laptop working again. replace the hard disk, install Windows on the new hard disk plus the HP Laptop's device drivers and your programs.
Mar 20, 2011 | HP Computers & Internet
Laptop boots up and says operating system not found
This error message occurs when the laptop/computer boots up and cannot find a hard disk and/or operating system.
This could be a faulty hard disk or disk controller.
First - re-seat the hard disk and reboot the computer. If this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirms the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a functioning laptop again.
Jun 10, 2010 | Acer Aspire 3680 Laptop
Turn on. Message: ''Cannot start. The correct
you try reformatting hard drive or restoring ps3 ? do a search for this warning u will loose and saved data on console. photos musics etc...
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
