-   I changed the bag a few times. My fiancee doesn't watch the lights but I definitely do. Now it seems that my 'guiding light' is stuck. I'm just looking for a way to reset it. -   Guest
Jan 10, 2009
-   Have had machine since July 2007, so after 1.5 years my dirt sensor won't go off either. This makes vacuuming that much more "work" as the unit is heavier when it is working harder. Gosh yeah plz, is there a simple solution for this? -   Bobo3497
Dec 06, 2008
-   I have the same problem, the red dirt sensor is stuck on and wont shut off. -   Guest
Nov 30, 2008
-   Seems like a sensor somewhere is clogged. It is permanently thinking the rug is dirty.-   aubinp
There is an optical sensor inside the port where you attach your vacuum bag. Take the bag off and take a clean soft cloth and wipe inside the port to remove dirt from the sensor. Don't wet it! Do this every time you change your bag and you shouldn't have a problem.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Kenmore 31912 Progressive
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
on my Kenmore Progressive Dircect Drive upright bagged vacuum, one day the motor was working hard,...
(More)
on my Kenmore Progressive Dircect Drive upright bagged vacuum, one day the motor was working hard, and the thermal overload switch must have triggered. I could not fix the problem by resetting the switch. Could the overload protector have blown out? I have been searching for one ever since. It says Hosiden BC 501
I took my vacuum cleaner apart to clean it because it was clogged inside and now I am having trouble...
(More)
I took my vacuum cleaner apart to clean it because it was clogged inside and now I am having trouble putting it back together. I am looking for a manual of some kind to show me how to assemble it. It is a Kenmore Progressive Model # 11636933502
I'm not sure if it is a worn belt or a worn agitator as mentioned in the instruction book but I'm...
(More)
I'm not sure if it is a worn belt or a worn agitator as mentioned in the instruction book but I'm hoping it's a belt that I can change myself. Can anyone tell me how to access the belt and how to replace it? I don't see what to open to reach the area. Thanks! Eileen
