The oven is not working. It is giving an error of F7 d7. There is no heat from the oven and there is no visible pilot light lit, as far as I can see. I am unfamiliar with this model and I need to know if this unit has a pilot light like most gas ranges, and what the error means. I am hoping it means I have to light the pilot light, and if so, how do I do that. The range works fine.
-   pilot light not on, no heat, not working. Is there a way to light the pilot light and get it working?
-   Guest
Jul 05, 2008
-   Well my stove all of the sudden a loud beeping noise started and a F7 number appears in the dash i would to know how to fix or what to do Thank you.-   ulloa_817
Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
oven stopped baking when the temp. probe shut it off (as planned, at 165) but it won't bake anymore....
(More)
oven stopped baking when the temp. probe shut it off (as planned, at 165) but it won't bake anymore. I've removed the probe and unplugged the stove for 30 sec., but the gas still won't come on for a bake cycle. The broiler and stove work, however.
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u...
(More)
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u recalibrate oven temp?
gas oven does not light right away resulting in a strong gas odor and causing it to bang when it...
(More)
gas oven does not light right away resulting in a strong gas odor and causing it to bang when it does light
