Question about Avanti Top Load Washer W797
Avanti W797: Tub won't spin or water does not empty.
My Avanti W797 is about 2.5 yrs old. It will not perform the spin cycle nor will the water empty. Hi, the water won't drain, rinse and spin after the washing cycle. The problem comes from the water pump but how to access it if everything is glue? Where is that magnet, what it looks like? tks a lot
  • 13,433 Answers
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Posted on Nov 08, 2008
Model W797. Why won't tub spin or water empty?
it could be 1 or any number of things , starting with the control board /timer ,broken belt ,gearbox pump . a repairman might be your only course if help
Oct 01, 2015 | Avanti Washing Machines
Avanti W797 wont spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Jan 12, 2013 | Avanti Top Load Washer W797
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
The machine does not perform last spin cycle
check lid..either the lid switch is bad or the lid switch actuator which is made into top...when in final spin push down on the right hand top part of lid,,,if it starts replace part needed,,,good luck
Sep 12, 2011 | Avanti Top Load Washer W797
Trouble with spin cycle
my machine does not want to spin and displayed me er1
Mar 06, 2011 | Avanti W797 12 lbs. Top Loader Fully...
Make sure the waste hose is sufficiently high enough above the ground to stop the water siphoning out. Try raising up the waste hose to approx 90cm / 36 inches.
Nov 10, 2009 | Avanti Top Load Washer W797
Have a Avanti 798SS Washer. Does not wash nor does it spin. I heard something with the motor as if it attempting to perform said task (wash) but in the end it beeps and E2 flashes. What does this mean?
Oct 21, 2009 | Avanti Top Load Washer W797
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Avanti Top Load Washer W797 Logo
467 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
