Question about Xerox 212 Laser Printer
J8 Error Code
Recently replaced the printer cartridge. Now the copier shows a J8 error code. The manual just says to call service. What causes the J8 code and how can it be fixed? Thanks.
    President:
  • 2,072 Answers
There are a few different part numbers for those cartridges, the chip on them bills differently.
A J8 means although you have a 212 cartridge, it has a chip on it that does not match your machine setup.
A J8 indicates a mismatch in the cartridges and the machine. No you do not have the wrong physical cartridge, it just has a different chip on it.
Posted on Nov 08, 2008
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Xerox copier 5614 stopped and posted error message J8; I cleaned the copier, replaced the cartridge with a new one, and after closing it up again, the J8 message continued. I have shut the copier down,...
This error code normally is for incorrect cartridge or not seated properly.
Trying cleaning on the copier cavity area that hold the cartridge. Make sure the power is off first.The sensors might be blocked by dust and dirt. Then reinstall the cartridge and try again. Hope this helps.
Feb 17, 2011 | Xerox 5665 Copier
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
System error E000202-OOO2
Is this the code you are getting? Intermittently Fuser Error Codes E001, E002, E003, E005 or E006 are occurring
Workaround :
A flat spot on the Fuser Rollers can cause Unit 1, the Fixing/Feeding Assembly, to vibrate which can effect the connection of connectors J8, J403 and J404 on Unit 1. If needed replace the Fuser Rollers, Bushings and Bearings. Then go into Service Mode Level 1> Copier > Option > Body > FX-CROT, change this setting to 3 to prevent flat spots on the fuser rollers from occurring
Mar 14, 2010 | Canon imageRUNNER C5800 Copier
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    E020 01BO What does this error code mean?
    E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
    01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
    Nov 16, 2009 | Canon CLC 1120 Color Copier
    Xerox 5614 has a j8 code and will not reset after I replaced the toner
    J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM
    Sep 17, 2009 | Office Equipment & Supplies
    Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
    I guess you're getting an error message which is normally one of the below (causes underneath)
    Error Code 931
    No first HYSNC Signal
    Error Code 932
    Lost HYSNC =
    These errors usually indicate a
    failure in the HYSNC signal to the
    printhead. Check the continuity of
    the cables connected to J3 and J8
    on the engine board. If incorrect,
    replace the defective cable. The
    voltage at J8-4 measures
    approximately +5 V dc. If incorrect,
    replace the engine board. The
    voltage at J3-7 measures
    approximately +24 V dc. If incorrect,
    replace the engine board. If correct,
    replace the printhead assembly.
    Error Code 934
    Mirror Motor Lost Lock
    Error Code 935
    Mirror Motor unable to
    reach operating speed =
    These error codes indicate a
    problem with the mirror motor circuit
    in the printhead assembly or the
    mirror motor cable to the engine
    board cable or engine board
    assembly. Check the continuity of
    the mirror motor cable connected to
    J3 on the engine board. If incorrect,
    replace the cable. The voltage at
    J3-7 measures approximately
    +24 V dc. If incorrect, replace the
    engine board. If correct, replace the
    FRUs in the following order:
    engine board
    printhead assembly
    Jun 19, 2008 | Lexmark Office Equipment & Supplies
    IR 2000
    Fuser error probally needs fuser replaced and the reset as below
    try this
    1. Hit Additional Functions Key
    2. Hit # key
    3. Arrow to number 7, Printer and hit Set
    4. Arrow to number 4, Printer Re-Set and hit Set.
    5. Yes, re-set printer (hit minus key - back arrow).
    6. Unplug the machine and plug it back in.
    or this is explaination of the error and required fix from service manual.
    E0000000
    Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
    Caution To reset the error, execute the following in service mode:
    Action
    1. Connector
    (open)?
    YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
    Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
    supply PCB.
    PCB.
    Nov 18, 2007 | Office Equipment & Supplies
    Xerox 212 Laser Printer Logo
    230 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
