Panasonic ax100 projector turns off after about 1 min of running. I power off the main switch and turn on again. It turns off again after another minute(green light turns orange). I repeat the process and then the projector runs fine. So it turns off twice when I first use it but then it is fine. I have replaced the lamp and filter so that isn't the problem.
  • 1 more comment
  • micktron Nov 09, 2008
    I have the same issue does anyone have a fix yet.
  • Anonymous Nov 30, 2008
    AX100 powers off aftter minutes of usage. Requires main switch off before can be turned on again. Then runs Ok.
  • Anonymous May 22, 2009
    Same issue, it turns off after 5 minutes and then after turning back on once or twice - its fine
Found issue is the Iris is sticking. Sent back for repalcement.
Posted on May 27, 2009
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
I have a panasonic projector model no.PT-AX100E. It is currently turning it self off after about a minute when i turn it on. There are no flashing on the lamp or temperature leds. The lamp has about 1100...
Enter the service menu under self check and you will most probably see that the fault is cause by the iris (will be in red). The iris needs to be oiled so that it can open and close again properly (you can find a youtube video showing you how to do this).
Enter Service menu like this:
From the projector being on, press the power button to turn it off then press:
Cursor left
Cursor up
Cursor down
Cursor up
Cursor down
Enter
Sep 04, 2010 | Panasonic Office Equipment & Supplies
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
try looking for your thermistor usually located near the wind path its a small block the size of two match heads usually mounted off the main board with two wires this is your 'heat switch' so to say, also check your fans are clean and running there is normally more than one.
May 15, 2010 | Hitachi ED-X8250 Multimedia Projector
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
Jan 04, 2008 | Office Equipment & Supplies
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
