Question about Panasonic PV-GS65 Mini DV Digital Camcorder
Mini dv won't record on new tapes
My panasonic pv-gs65 mini dv won't record on new tapes. everything else works fine. ironically, it will record on recored tapes. any help?
SOURCE: PV-GS9 mini dv playback problem
I have the same problem, Try to go on record view and record for 2 sec and come back to play back. It should work tamprarly. I am looking for a permanent solution. If you find one let me know!
Posted on Oct 12, 2007
  • 156 Answers
SOURCE: How to capture recorded vedio from Panasonic NV-GS15 Mini DV Digital to Laptop
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
Posted on Oct 23, 2007
  • 3 Answers
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Posted on Sep 21, 2008
SOURCE: Upload content from PV-GS65 to LAPTOP
there should be a usb port on the camera. below the mic in, under the flap to the right of the on/off.
should be able to get this cable at any office supply/ camera store.
Posted on Jan 19, 2009
  • 148 Answers
SOURCE: Blue bars during playback
Your heads are dirty , clean with a cleaning tape.
Posted on May 12, 2009
  • 14 Answers
SOURCE: I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
Posted on Jul 07, 2009
0 characters
1 Points
I have a Panasonic PV - GS65 mini dv . When i press record it works for a few seconds and then it stops and tells me to push the reset button . After that is don it continues to do the same thing
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Nov 07, 2010 | Panasonic PV-GS65 Mini DV Digital...
I lost the disk to my pv-gs65 camcorder how can I get another one so i can use my usb connect?
This CD had a driver on to allow your camera to connect to a windows PC, however unless you have XP the chances of your camera driver CD working is less that 5%, you need to pop into Ebay, type what you need in search bar, and who know you could be lucky.
Jun 10, 2010 | Panasonic PV-GS65 Mini DV Digital...
Panasonic pv-gs15 will not play back recorded video in the mini dv deck. all i see is a blue screen with red text ''picture'' on bottom right corner of the screen
Make sure your tape tab is open. See if this works. Sometimes the tab should be closed to prevent eraser or recording over existing film but sometimes the tape tab has to be open to allow for playback or dubbing?
May 28, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
PV-GS65: Tape won't come out
u must open the camera and just remove motor connector and put 3 dc volt suppy on motor then it will wok
Jul 08, 2009 | Panasonic PV-GS65 Mini DV Digital...
Jan 13, 2009 | Panasonic PV-GS65 Mini DV Digital...
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Vista driver
need panasonic usb pv-gs65 drivers cant fine any where dose now where to get it have copy email to me
Apr 21, 2008 | Panasonic PV-GS65 Mini DV Digital...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
Panasonic PV-GS65 Mini DV Digital Camcorder Logo
20 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
