Question about Motorola Mobility RAZR V3
White screen I have a Motorola K1, it's 2 years old but not used so brand new. I put my sim card in the other day and made a couple of calls. The inside screen has gone white and not showing anything. The outside screen still displays as normal. You can receive calls and make calls by putting the number in manually, the ringer works. Any ideas. Thanks Dave
    Brigadier General:
  • 7,752 Answers
Take the phone and have the lcd replaced on the phone from a mobile service center
Posted on Nov 10, 2008
How do I put my sim card into a Motorola 120T
you follow instruction in user manual........
Jul 02, 2012 | Cell Phones
My daughter was given motorola razv3 the vodafone sim card is very old and says it;s not registered, will a new vodaphone sim cure it.and she wants to have it unlocked to use o2 sim. HELP PLEASE
ya sure you can unlock your motorola mobile and use it with any network ......
With the help of the codes you can unlock your mobile,
Get the unlock code for your Motorola Razr V3 model mobile from this site , here get the unlock code for your mobile along with easy instructions and methods.........
Nov 14, 2011 | Motorola Mobility RAZR V3
My lg ct810 screen just freeze an only incoming calls work
While the handset is on, take the battery out, wait 1 minute, then reinstall the battery, and power the handset back up. This should resolve the issue. If the device is less than 1 year old, At&T will replace it with another one. This process is called exchange by mail, and it only takes a couple of days to get your new handset. They even provide the pre-paid return label, so all you have to do is take your sim card out of your old device, the battery and memory card (if applicable), install them in the new device, and power it up, there is no need to call to activate the new handset. Place the old handset in the box, place the label on it and put it in the mail.
Motorola i570 battery died while I was talking on phone. When plugged in to wall charger directly after it died, I turned the phone back on and the display screen is blank white. Had the exact same problem...
Your contacts are stored on your SIM card. You can unplug your SIM card from your old phone and slide it into your new phone (if it is another i-series Motorola phone) and all your contacts will be in your new phone. You should not lose anything except the record of your recent calls.
Jul 09, 2009 | Motorola Mobility RAZR V3
Sim card not working with my ic 902 phone.
try to reformat the sim before inserting it in phone. also make shure to not exceed sim memory size or speed.
May 04, 2009 | Motorola Mobility ic902 Cellular Phone
Need master password for my samsung sgh-c425
I found this off another site. I have tested this withy my D807 and it works.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin)
3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone.
Jan 03, 2009 | Samsung SGH-C425 Cellular Phone
Call failed on ALL calls
I would call your service provider to confirm your SIM was activated correctly.
Nov 18, 2007 | Motorola Mobility V31 RAZR GSM Cell Phone,...
Brand new Motorola PEBL dropping calls
you should try a master reset and clear....then connect back the wireless if the same problem occurs then try upgrading the firmware or have it reflash...that can be done by taking the phone to a mobile service center or mobile professional technician.
Oct 28, 2007 | Motorola Mobility PEBL U6 Cellular Phone
No reception? HELP??
It sounds like your phone is not unlocked. Did you get the phone through a different provider and your sim card through some one else? For ex, here in US, a cingular SIM will not work in a Sprint phone.
Jul 25, 2007 | Motorola Mobility RAZR V3
Cell phone no service
unregistered sim card? if thats the prob. maybe som1 else is using ur phone # like a replacement sim. if not check the network frequency
Mar 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
