Question about Frigidaire FEF352 Electric Kitchen Range
Self cleaning oven instructions
I have the Frigidaire Gallery oven and when I try to use the self cleaning feature it just beeps at me and says "door".
  • Anonymous Nov 29, 2008
    trying to start the self cleaning on a frigidaire oven and all it does is beep and says door lock
  • Anonymous Jan 12, 2009
    same with me ... I have used it a couple of time before but now I am getting the same thing ..I push the button for clean and the display says "dr" and beeps over and over again ..
That use to happen to me, one day I took the top part off and I seen that on the other end of the lock hook was full of oil gunk, after cleaning it, it works fine now.
Posted on Feb 16, 2012
My oven is beeping and display F 1 what does this mean
Posted on Feb 18, 2009
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Self cleaning feature does not start.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 04, 2010 | Frigidaire Gallery 30" Self-Cleaning...
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Frigidaire 30 in. Electric Gallery Series...
Lost the manual. How do I use the self-cleaning function on the Frigidaire Gallery oven?
Before you run that self cleaning feature, check out this tip that I wrote...
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 08, 2010 | Frigidaire Gallery GLEFM397DS Electric...
The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
heatman101
Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
Cant get the oven to turn off from the cleaning setting and its just making a loud beeping sound, had to unplug.
After unplugging, allow the oven cooling down for few hours.
If the beeping restart, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 02, 2010 | Frigidaire Gallery 30" Self-Cleaning...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Self-clean feature
hi .thanks for the question. f 3 on Frigidaire stoves, mean an open oven sensor. located in the oven top left corner, looks like a pen . replace the sensor. thanks the appliance doc
Oct 05, 2008 | Frigidaire FGF355FS Kitchen Range
Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
Jul 12, 2008 | Kitchen Ranges
Frigidaire FEF352 Electric Kitchen Range Logo
551 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
