Question about DHD NTX-8496 Car DVD Player
Tview DVD 799TS-BL
I recently bought a Tview DVD 799TS-BL brand new. I installed it but everytime I have the monitor out it freezes for a while and them it works. For the life of me I can not figure out the problem. Can someone help me . Thanks
What causes a Tview T244IR-BK not to power on when all fuses are good and where to buy replacement parts
That worries me when the fuses dont`t blow,otherwise I would have told you you made the wrong connections or did not ground enough. You can find fuses in any hardware stores and if your purchase is recent, have it replaced or get your money back. I suspect something wrong with the item. Or go to place where they are specialized in installing DVD monitors in cars; they`d tell you if it`s blown up or not. My TView monitor is really blown up and I am trying to find out if it can be fixed. My warranty has expired and I am kind of stucked.
Sylvain, Blainville, Canada
Aug 08, 2014 | Tview T244ir 24" Black TFT Wide Screen Car...
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
The USB will not work on it
shake the usb cord near the screen or move it side 2 side should read it then!
Jan 27, 2011 | T-View TView (DVD170TV) Motorized 7"...
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
Tview DVD799TS-BL need manual. Where find it?
http://www.tview.us/manual/DVD799TS-BL-manual.zip
Dec 21, 2008 | Car Audio & Video
TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Feb 24, 2008 | Car Audio & Video
WIREING
Not familiar with that brand, but it should use the international standard colors: yellow- battery red- ignition black-ground white- left front + white/blk- left front - gray- rt front + gray/blk- rt front- purple- rt rear + purple/blk- rt rear- green- left rear+ grn/blk- left rear -
Sep 13, 2007 | T-View TView (DVD170TV) Motorized 7"...
Need manual
the manufacturer is universal electronics, you can find their contact info on their website at www.tview.us . good luck
Jan 06, 2007 | T-View 15.3" Overhead Monitor w/Built-in...
DHD NTX-8496 Car DVD Player Logo
406 people viewed this question
Top DHD Car Audio & Video Experts
Jeff Turcotte
Jeff Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
