Question about Hotpoint Kitchen Ranges
Stove Hotpoint Model KS839-JT2. Digital clock reads reset and unable to get heat in oven, because the digital temperature goes back to reset.I have unplugged it and removed all the fuses. Reset the clock and it reverts back to reading reset.
  • 76 Answers
SOURCE: Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Posted on Jan 07, 2007
SOURCE: Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Posted on Dec 20, 2007
jsrock516
  • 5911 Answers
SOURCE: oven burnout
The oven is controlled by an Electronic Range Control (ERC). This is the clock assembly on the range. The surface elements are powered by infinite switches and do not go through the ERC. That explains why the clock assembly is dead, your oven does not work, but your surface elements do. You need to replace the ERC. If you can provide me with a model number (located near the oven door or bottom drawer opening on most ranges, on the back of the console on some) I can determine what type of ERC you need and how much it might cost you. Post back with comments and let me know if I can be of further assistance. I hope this helps you.
Posted on Feb 11, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
  • 116 Answers
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
If the oven was working before then
1. Power is gone from the unit - loose connector or neutral wire ( or ground wire depending on wiring system being used)
2. The power supply transformer (or transistor) on control board is busted. This is especially true if there was power problems in the apartment- power going on and off frequently. Check the wiring and see what comes up. Hope that helps
Regards
Posted on Sep 04, 2008
CONVECTION OVEN CONTINUES TO GIVE fault code and doesn't heat
you either have a bad sensor or a bad clock assy. change the sensor first or check it with a meter it should read around 1080 ohms if this is good you have a bad computer board or clock assy. same part.if this a slide in stove with the burners on top there should be a tech sheet on the back,if this is a wall oven there should be a tech sheet below the top panel,slide it out and tilt it forwards enough to remove the top panel and of course kill the power to it first
Nov 03, 2017 | GE Ovens
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
Dec 16, 2013 | Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint older stove don't have the model # at this time. the digital display on my oven stopped working { stovetop works fine). After about 2 months of nothing all of a sudden it lights up...
The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Gene
Aug 03, 2011 | Hotpoint RB790SHSA Electric Kitchen Range
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
May 21, 2010 | Hotpoint RVM1325WW Microwave Oven
Oven over heating-control does not work
ths oven looks like it has a digital clock (eoc ) it has a sensor in the oven in the back/ ( oven probe) replace the probe first . you may also need the clock . its very expensive .mm
Nov 22, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
Kitchen Ranges Logo
46 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
