Question about Toshiba 50A61 50" Rear Projection Television
Toshiba 50A61 Horizontal Lines in picture
Ocasionally when watching, horizontal lines appear in the picture. Tapping on the side of the TV makes them go away. Problem is getting worse. The TV is about 5 years old and has been moved several times and sits next to my large subwoofer. Seems like when the subwoofer is on the problem happens more frquesntly. Im thinking something has worked loose but knowing nothing about TVs I dont want to start poking around without any idea what Im looking for. Any help would be appreciated, what to do, what not to do, what to look for, what to test??
  • vefam
    vefam Nov 29, 2008
    i have exactly the same problem, and even the fix seem to be the same,
    when I tap either side of the tv, altough I don't have nothing but a DVD player in top of it, but I don't think that is the problem, I got my singnal thru
    a smart cable, but I even tried the regular RCA cables (audio y video)
    an still the same problem. at first the problem was light, then worsen real bad, to the point that we had to tap it every 5 mins. or so, but then all of a sudden the problem reduced itself, to dont see anithing wrong for a couple os days and so on..........
    please help out.......the image is incredible, even though is a projection tv.
    I opened the tv, cleaned the lenses, the reflection mirror, and the 3 projction pannels, and the result was an jaw dropping ending ( highly recdomended to do!!!!)
    please e-mail me if you know something.....
    vefam@msn.com
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
You have bad connections somewere need to look further for sure
Posted on May 05, 2010
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
CRT TV picture keeps getting horizontal line & loud cracking nois
the horizontal section is near collapse, the lines indicate a sort or leak. Soon, the set will go black. Shut off as repair will be cheaper now! Needs professional repair as High voltage section is dangerous.. Unplug to be safe!
Mar 13, 2009 | Toshiba CF27F30 TV
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Horizontal lines
If this model has a "lint screen" or air filter, I would check to make sure the set is getting proper ventilation. Otherwise, you probably have a bad solder connection or capicators going bad, causing your symptoms. Hopefully you won't have to get a replacement Printed circuit board as they are quite expensive.
Jan 02, 2007 | Toshiba TheaterWide 62HM84 62" Rear...
Beautifull picture except for a jiggling black line in pricure
your tv is having horizontal problem take it to a tech in order that the hrizontak deflection circuit be checked it also might have abad yoke
Dec 28, 2006 | Samsung TXF2899 28" TV
Toshiba 50A61 50" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
