Whirlpool Washer Won't Drain
I have a Whirlpool washer LLC7244BZ0 that usually won't drain from a cycle. I have to play with it until I can find a drain cycle that will work. I've replaced the timer but that didn't solve the problem. There isn't a problem with the drain hose because it will drain when it decides to.
  • hitz1 Nov 09, 2008
    The only thing I replaced was the timer itself, part 9 on the drawing. I'm not finding the timer motor on the drawing. Which number is it? I'm thankful for your help.
    Scholar:
  • 60 Answers
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LLC7244BZ0.cfm
Posted on Nov 09, 2008
  • tnmatt Nov 09, 2008
    There are two types of timers that are availability for your washer. Since you can't find the timer motor than yours is built in to the timer. The timer motor is the little motor attached to the back of the timer. It plugs directly to the timer. After the tub fills up with water the water level switch carries the circuit back to the timer which starts the wash or rinse cycle. After the tub is drained it sends the circuit back to the timer telling it to start the motor to drain. If this switch is not working correctly than the timer will not advance. Watch your timer during a wash or rinse cycle. If it advances any during that time than the timer motor is advancing. If it stops at the end of the wash/rinse cycle and just stays there that would indicate the water level switch is faulty. This is what your water level switch looks like. Check the tubing for leaks. It operates off of pressure. As the tub fills pressure builds and forces air up the tubing until it satifies the switch. Pressure decreases on the drain cycle.
    http://www.repairclinic.com/SmartSearch/...
    Should you wish to order one go here, scroll to the bottom
    For a picture of all the parts of your washer go here:
    To see a picture of the timer motor, if yours is external go here:
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
Won't finish cycle
If you can't see a clean out drain on the bottom panel pull the panel off (three screws on bottom)...you will see the drain pump unscrew the clean out (get a bucket) these models won't finish a cycle unless ALL the water is out. nine times out of ten this is the problem. Hope this helps.
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
