Question about Whirlpool GGQ8831L Gas Dryer
Heat only when it wants to
I replaced the coils and the igniter and it still cuts out on the heat. I know not to touch the igniter when installing. Could there be something else. I can geat the gas valve click open, and some times it does get warm, but after awhile no heat. What a pain in the ****. I thought I was getting some brownie points with the wife for fixing it myself...
It will cost you $15.00 for me to tell you...
Posted on Nov 09, 2008
Dryer cuts off soon
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Apr 30, 2014 | Frigidaire Dryers
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
Loose fire after 10 minutes of riden
Not much information here but the first thing I would look at would be your ignition coil followed by your stator. It is more likely to be your stator (they can build up heat then cut out only to cut back in once temps have dropped ) but this is harder to check whereas the ignition coil is easy to get to and replace for not too much money. Never hurts to have a spare coil around.
Testing of the stator requires a mulitmeter and a bit more knowledge. Replacement of the stator is much more work than replacing the ignition coil.
Jul 31, 2013 | 2004 Yumbo Dakar 200
1998 harley davidson cuts out when bike gets warm
Check the ignition, pull the points cover off and then put a heat gun on the ignition and heat it up to see if the bike will cut out. I know you replaced the coil if you can check it again to see if you have 12 volts coming and in and out of the coil after you get it to fail just to double check thats the problem.
May 16, 2010 | Maisto HARLEY DAVIDSON MOTOR CYCLE 1998...
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
Our kenmore # 110-728220 turns but no heat. replaced ignitor still no heat
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 13, 2009 | Kenmore Dryers
Gas dryer not heating
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Jun 22, 2009 | Frigidaire Dryers
Dryer heat starts then no heat
Hi, the most common issue will be a set of defective coils but, i suggest that you run through all points and check all the listed check points before replacing the coils.
1. Gas valve coils
2. Thermal fuse
3. igniter
Jun 18, 2009 | GE Dryers
Dryer burner just stopped working. the motor turns but no heat. It also will not start on timed heat.
HI, i recommend inspecting all areas stated below to address this issue. the most common problem will be a set of defective gas valve coils but, i suggest checking all points before replacing the coils.
1. Gas valve coils
2. Thermal fuse
3. igniter
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Alg331raw gas dryer. Runs but no heat. Worked
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
