Question about Lucent Cajun P333T Networking Switch
How can I reset it back to original configration
How can I reset my Cajun P333T Switch back to the original configuration. I tried to change the IP address of it and i realized afterward that there was a conflict between IP and subnet. Please help me, a prompt answer would be most appreciated. Thanks, Eric
  • Anonymous Nov 13, 2007
    I would like to know how to reset lucent cajun switches
    Kofi
    Problem Solver:
  • 6 Answers
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info: - Free IP to assign to the switch - Subnet - Gateway (If you ping such IP from a machine of same subnet, there will not be an answer). Then log as superuser (#) and do this: 1. Type set interface inband Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter. (for VLAN you can list them and decide which one to use, but normally you should use 1) 2. Type reset and press Enter to reset the stack. 3. After the Reset, perform login again as superuser.  4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use 0.0.0.0 as destination, list routes set on device for more info) 5. Press Enter to save the destination and gateway IP addresses. That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access. Good Luck!
Posted on Aug 11, 2007
Modem light flashing orange
what u can try is ... if u have the details for the configration... reset the router by pressing the reset button and hold the reset down for 10 to 15 secs and the router will restart ... go to the router configration page and re configure it ... and see if it works and if u still get the orange light call ur ISP and if u do not have the configration details in that case too call ISP
Jan 30, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
How do i reset the login and password?
You can reset it with pressing RESET button for 10 seconds it is in the back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Let me know if you need further assistance. Thanks for using FixYa.
Jan 15, 2011 | NetGear WGR614 Router
Sir I Have DLINK DES 3526 L2 mangable switch, its earlier configured an ip which is 192.168.1.17 using this ip i access the switch yesterday and i change it to the DHCP configure but now i want to allot...
All Dlink routers has a reset button at the back. Just use a paper clip to press and hold that button hole until the router turns off itself and restarts again. Your router will then return back to defaults with 192.168.0.1 IP address.
Please let me know if this helps. Thank you for using FixYa.
Oct 08, 2010 | Computers & Internet
How can i administrate a cajun p115g because it dosn´t have a console port?
open up internet exploer on any machine and type ip address into the url bar the default is usually 192.168.1.1 but yours maybe different to know your ip address open up your command prompt and type in ipconfig
to open your command prompt in windows xp click run from the start menu and type in cmd
if it is Vista then type cmd in the search and choose the first option
Oct 21, 2009 | Lucent Cajun P115G (108360850) Networking...
I changed my dlink dir-300 router's ip address to 192.168.0.2.now i cannot access the page.did i spoil it?what can i do now?can i reset it?will resetting it change d ip address back to 192.168.0.1 ?please...
Yes, resetting it will revert it back to factory settings (and therefore original IP address). Sometimes it is best to start over when something like this happens. ;)
Remember though, if you are configuring your router with a wireless connection you need to disconnect/reconnect to you wireless network (because you just changed it's address).
Aug 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Need to know the command line commands for Avaya Cajun P333t switches
cajun switches have pretty similar command structure as cisco. use the ? mark for help.
Jun 03, 2009 | Lucent Cajun P333T Networking Switch
Cajun P333T doesn't accept input from serial
All info from juliankov appears good.. but thought I'd add a bit of stuff I found on a web site..
http://www.tek-tips.com/viewthread.cfm?qid=300461&page=2
Use a console cable with following minimum pinout (the flat gray one with the RJ45- D9 type converter currently shipping with new P33xx switches will suffice): DB9 Console Port
1 ----------- 6
2 ----------- 3
3 ----------- 2
4 ----------- 4
5 ----------- 5
6
7 ----------- 8
8 ----------- 7
9
Obviously the speed is set to 9600
maybe stop all sessions & try to re-establish a new one. The instruction manual warns u can only run one..
Mar 10, 2008 | Lucent Cajun P333T Networking Switch
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Help me with a Cajun p333t
it is reseting because it dosent have a lot of branwith
Sep 13, 2007 | Lucent Cajun P333T Networking Switch
Save config
After changing all the necessary parameters using the CLI, use the write command to save your system configuration. If you receive any error messages, your configuration has not been saved. You must correct the errors and re-issue the write command. Notification of write errors is presented in a two column display: ? The left column contains the parameter values that you set in this session and need to be changed. ? The right column contains the parameter values currently saved in the Cajun P116. Wait 15 seconds for confirmation of the write process. Then exit Privileged level by typing exit at the prompt. For example, CajunP116-priv# exit. The cursor changes to CajunP116> to indicate that you are in Normal level. Verify that all the parameters were accurately saved by using the show all or show all list command. The Cajun P116 is now ready for cabling and operation. You may exit your CLI session.
Aug 23, 2007 | Lucent Cajun P116T (108360843) Networking...
Lucent Cajun P333T Networking Switch Logo
1,153 people viewed this question
Top Lucent Computers & Internet Experts
D. E. Hev
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
