Question about Sony CPD G200 (White) 17" CRT Monitor
Monitor HZ problem
Hi, a friend of mine has adjusted his hz from 75 to 250 and it goes black, but runs perfectly fine in the BIOS. What can be done about this ?
    New Friend:
  • 99 Answers
Try booting in safe mode and reducing the resolution and the refresh rate to a value which the monitor can handle
Posted on Nov 08, 2008
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Aug 28, 2017 | Compaq FP 5017 15" Flat Panel LCD Monitor
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the...
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Nov 14, 2009 | Westinghouse LCM-19v5 Monitor
Blury picture
I had the same problem.
Just fixed it.
Check the cable on the back of the monitor.
Make sure it is plugged in properly.
Wiggle it a bit, and the ghosting dissappears.
Don't tighten the cable to the PC too much.
Jan 13, 2008 | ViewSonic VA903B Monitor
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Sony CPD G200 (White) 17" CRT Monitor Logo
450 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
