Question about Avanti Top Load Washer W797
The water doesn't stop. The machine fills with water and never stops. I just bought this washer. I'm guessing that something's wrong with the sensors because the machine doesn't seem to recognize that its filled with water and should start washing ad stop getting any more water. I'm super fustrated and can't figure this out! Help!
  • zouzouka Nov 08, 2008
    I really appreciate your answer. The problem is that today is Saturday and the service call center is going to be open on Monday. Unfortunately I assume what I have to do is just wait until Monday and use the laundromat for one more weekend...Thank you very much for your reply though.
  • Carole Steele Sep 26, 2011
    My washer overfills. Why?
  • 5,911 Answers
I'm not familiar with your model washer, but most overfill problems are attributed to either a fill valve that does not shut off properly (this is where the fill hoses connect to), or a pressure switch malfunction. The pressure switch is what determines at what point the washer shuts off. Since you just bought the washer, I'm assuming the water inlet valve is probably NOT an issue, because the problem I mention with it not shutting off, is usually attributed to sediment build up. The pressure switch is controlled by a pressure hose and an electrical connection. If the electrical connection is intact (no corrosion or broken wires) and the air hose is connected and has no holes or slits, I would rule that you may have a bad pressure switch. However...It is common for the air air hose to come loose on the pressure switch and fall off. This can happen through normal use due to vibration, or during shipping. The result: a pressure switch that no longer senses the water level and will not shut off. This is easily resolved by re-attaching the air hose. What appears to be a very serious problem can often be something as simple as reconnecting a hose. Now...if you just bought the appliance, I would NOT recommend you open it to inspect. Most appliances come with a limited one-year manufacturers warranty. You can void this warranty by opening the appliance. This is the only time I would recommend you place a service call. I know this may be an inconvenience to you, but the service should be FREE if still under warranty. If you end up damaging something attempting a repair on your own, the repair would be YOUR responsibility. If you cannot find your sales receipt, the appliance serial number will determine the manufactured date and the warranty should STILL be honored. I hope this helps you. Let me know if you still have questions.
Posted on Nov 08, 2008
How do I troubleshoot if My kenmore washing machine fills with water and then stops
It is more than likely the lid switch. Most modern machines will fill with water and then wait for the lid switch. If it is bad they will just sit there.
Jun 27, 2014 | Kenmore 22422 Top Load Washer
Lg washer fills, starts to wash but stops
have you checked brushes on motor
Jan 27, 2014 | LG Washing Machines
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Washer doesnt stop filling up with water
There is either something clogging the air tube to the water level sensor or the water level sensor itself is bad. If you need help accessing the air tube or water level sensor feel free to ask.
Dec 01, 2010 | GE Profile WPRE6100G Top Load Washer
We have a GE top load washer with the model number WDSR2120J. It new (almost 13 months old so the warranty has just expired.) When we turn it on, it won't stop filling up when it is full. Bubbles then come...
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
Jul 01, 2009 | General Electric WDSR2120J Top Load Washer
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Nov 08, 2008 | Avanti Top Load Washer W797
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Avanti Top Load Washer W797 Logo
186 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
