SOURCE: Maytag Legacy Series Dryer will not start
Welcome,
Your temperature is to high and running wild . So the system has shut it down for safety reasons.
You need to call service for a diagnoses
if you do get it running, do not leave it unattended or better yet do not use it as is!
Send me the model number and I can send you the schematics!
Thank You for trusting us with your questions.
Huum
Please remember to leave a solved rating before you sign off!
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
SOURCE: Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
SOURCE: dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
I have a Gallery Series Frigidaire GAS dryer - Model GLG02152ESO.
I have an E68 readout, flashing lights & lots of bleeping going on.
HOW CAN I SOLVE THIS ISSUE?
Thank you.
