Question about Brother MFC-8220 Fax
Stuck Drum Hi. My Brother DR510 drum is stuck in my Brother MFC-8220 and I cannot push it in or take it out. What do I do now? Help!
  • Mary Fleming
    Mary Fleming Mar 06, 2015
    It worked, thank you so much. I called the company and they wanted to charge me $129.00 Love this site
  • 286 Answers
When you open the front door, there should be a sliding lever attached to the door on the left side. This lever should pull out when you open the door. If it does not due to becoming detached, you should pull it out by hand. Now you should be able to remove the drum. Check the door and see why the lever became detached. You should be able to remove the door and pick up a new one at your local Broother service centre. One other thing to note, sometimes people will use generic toner cartridges. I have seen these toners get jammed up and break the gears inside the machine. If this is the case, you will most likely have to bring it in to a service centre.
Posted on Feb 06, 2009
How to replacement drum brother mfc 8220?
pull out the toner cartridge.
The drum is the small caddy that the toner sits into.
May 22, 2011 | Brother MFC 8220 All-In-One Laser Printer
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
Is the drum and ink are on the same cartliage?
No they are not. The drum unit (DR510) is a separate cartridge from the TN570 toner cartridge. The toner will last around 6,000 pages while the drum unit is good for 20,000.
Good Luck and Thank You for using Fixya.
Sep 12, 2010 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Oct 28, 2009 | Brother MFC-8220 Fax
I changed the drum in my Brother MFC-8220 but the warning light will not go away. How do I make it go off?
Open the front door press and hold the reset key in.It will ask if the drum is replaced.select yes
Aug 17, 2009 | Brother MFC-8220 Fax
Cannot remove Drum on MFC-8220
When you open the frunt cover ther is a black hinge / leaver attached to the cover on the left hand side that disengages the drum unit drive, if this is disconnected / broken you will not be able remove the drum unit, an engineer may be required
May 16, 2009 | Brother MFC-8220 Fax
Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Feb 28, 2009 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC-8220 Fax Logo
211 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
