Question about Aiwa AV-D77 Receiver
Issue with the power. Reset doesn't work.
Power button does no more than click. When I use the power-enter buttons to reset, sometimes it goes into this repeating clicking cycling the power about every 1 sec.
Is there a simple solution (i.e. changing out a transistor or latching relay)? Or... do I just generate another piece of junk?
Thanks for your time.
  • 4 more comments
  • clue Nov 11, 2008
    Thank you and I would appreciate the help. I do have the service manual downloaded. What I meant by junk is that if I cannot repair this receiver, then I will be generating another piece of garbage. I would much rather prefer not to generate the refuse and keep the beautiful Aiwa receiver. I've used it for years and have had much pleasure out of it.
    Thanks for any assistance you can provide.
  • Anonymous Dec 03, 2008
    i have the same problem
  • atownballer8 Dec 03, 2008
    so what was the problem because mine is doin the same thing and its is pissin me off cuz i dont kno whats wrong
    so what was the problem mine is doin the same thing it is pissin me off because i dont kno whats wrong i look thru the manual an still can find it
  • canex500 Dec 31, 2008
    I have had the same problem for years. i don't have a fix for it but i do have a way to avoid it. in order to turn it on you have to press ''enter'' and ''power'' simultaneously. The clock then appears and needs to be set. set it and then press enter. then press power before it shuts down (within about 1-3 secs). Now it should be on. now you have to turn off economy mode (power saver). by doing this when you turn the receiver off, it will power down to a sleep mode and dispaly only the clock. this way it never completely shuts down(ie. relay stays contacted). this way you'll only have to curse and swear everytime the power goes out or the unit is unplugged. hope this helps
  • jr2112 Feb 28, 2009
    i have the same problem and the power and reset do not work it still just clicks wish i could fix this its aggravating and how do you turn the energy saver mode off??
  • 10,594 Answers
If you know basic electronics and can recognize parts inside receiver, then I'm here to help you but please don't call it as junk. Its beautiful piece of Aiwa.
Posted on Nov 08, 2008
  • Shahid Electronics
    Shahid Electronics Nov 08, 2008
    You need AV-D77 service manual to rectify the problem.
  • c_young73
    c_young73 Oct 17, 2012
    have both manuals and it doesnt help.. would be willing to exchange numbers if you can walk me thru process
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
Tip
Resetting the Ink Waste Absorber Error Message
Below Works with most Canon Range of printers.
By using this tool you can reset the waste tank counter and can sometimes reset the ink level monitors.I have included two procedures.
Method 1 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Method 2 First you need this tool : http://www.ziddu.com/download/14685220/PCM_servicetool.rar.html
Then the following steps: Step 1: enter in service mode in order to use the resetter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Then Press Resume button 5 times then let both buttons go.
  • The Alternate Blinking error is gone: the printer is in Service Mode state.
Step 2:
Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
I hope this helps anyone who has a issue with the Error codes. You can usually reset it 2 times before it will actually overflow. It can also assist in re-setting error codes
RegardsGM
on Apr 21, 2011 | Office Equipment & Supplies
I have a linksys router and i have tried to access the configuration menu. I have tried the common 192.168.1.1 with no sucess. i have even looked at my details for the ip and it is 192.168.24.1. That does...
Resetting by pressing the button for a total of sixty seconds usually works! While holding the button you can also power cycle the router once or twice. That should put the router back to default settings. Its frustrating sometimes but usually works by prolonged resetting and power cycle. Good luck!
Sep 06, 2011 | Computers & Internet
Canon pixma mp 160 printer is not printing it just shows E & 5 altenately.Please solve the problem Jayaram
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Errer code 5
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How do i unlock my samsung galaxy i forgot the unlock pattern and it is asking for my g mailaccount login which i do nt have
There is a thread at Android Forums about this -> link.
But if that doesn't work, well there is no other option except factory reset.First try to enter Recovery Mode. There are a few ways to enter in Recovery Mode -> video link.Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears)3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
Jul 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
Canon mp190-eror e5
Hello and Welcome to FixYa!
Try to reset the printer, follow the instructions;
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
May 07, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Ink asorber full
Hey welcome to Fixya.
If the waste ink absorber is full, you need to reset it.
First of all to solve it you need to download PCM Service tool. Download it from Here
After downloading follow these instructions
Step 1
: Enter in service mode in order to used the re setter:
  • The Alternate Blinking error is gone, the printer is in Service Mode state
Step 2:
  • Extract the PCM servive tool resetter and then double click "servicetool.exe"
  • You have done.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 25, 2011 | Canon PIXMA MX310 All-In-One Printer
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Aiwa AV-D77 receiver power issues
Please confirm 9 volts on Power Board as shown in below picture...
Regarding click-click-click sound of relay its caused by Serial Clock and Serial Data signal failure in digital ICs. Please confirm above signals by using Oscilloscope.
Nov 22, 2008 | Audio Players & Recorders
Aiwa AV-D77 Receiver Logo
448 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
