Question about Pioneer SD-P6091K TV
Pioneer SD-P6091K problem with turning it on
I'm having same problem as the following and i need a solution for this. I don't think i can repair it by myself so any suggestions for how i can get it repaired? I am helping a friend fix his Pioneer 60" Projection tv that just decided to cutoff during viewing, then he unplugged and reset the tv, it came back on then went off during viewing again. Now it will not come on! You hear power come to the PS board and you get the red standby light but nothing else. I can't find a schematic and I have heard varying opinions on Convergiance Amplifiers or Flyback or the entire high voltage board needing to be replaced. I would appreciate any ideas or at least where yall think I should start in trouble-shooting this problem. Thanks!
  • Anonymous Aug 22, 2008
    same problem. Mine just shut off comnpletely. red indicator light comes on then push power green light on then back to red. No picture or anything. HELP, don't want to junk this, but don't want to spend a fortune fixing it.
    Scholar:
  • 68 Answers
Is this set several years old, and has it been good till now? There is one on the internet, 8 years old for sale with the same symptoms as your friends. There is an internet site `tv-forums.com. Presumably you have already looked with the back off. Make sure there is not a build up of dust, which will cause overheating. If it has a 150 watt UHP lamp, or similar,(expensive!) it may need replacing. The lamp must be cooled by a fan, so make sure this is srill working. There should be a thermal cutout which automatically resets.
Posted on Oct 25, 2006
SOURCE:
Avic x910bt head unit continues to reboot at splash screen , tried firmware update but since it never actually boots it won't read the SD card , please help
Press the MENU and MAP during power up with the SD fireware 3.02X inserted. The screen will turn white with the words UPDATING, I have all ready updated my unit a year a ago before the rebooting problem. I just go this problem also i evenually got in to boot after eleven cycles of rebooting. My firmware updates were missing for the bluetooth and O/S. I reinstalled both updates and I still have the same problem. Its odd that everyone is getting this problem around the same time. I think its an intermitenground or resistor that is just from aging. Pioneer want a flat rate of $200.00 for all repairs.
Nov 30, 2010 | Pioneer AVICX910BT Car DVD Player
Pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Feb 25, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Convergence board cracked?
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Feb 02, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Colors not aligned
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs first. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. These should be readily available for about $25 each. There are 2 of them.
Keep us posted,
Dan
Aug 01, 2008 | Pioneer SD-P6091K TV
50" Pioneer TV blacks out and has shadow on the bottom third
yes it is worth fixing.if you r getting it repaired for the first time.
but you will have to wait for some long time to get it repaired as the tv is very old its very difficult to get the parts for reparing it.
the problem what you r facing is the problem of the convergence in your main board of the tv.
it has to be repaired.
i will advise you to get it repaired as it will work.
for doing it your self you can try clicking this link and following the given instructions in it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Jun 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 - Red bowing at the bottom of the screen
Convergence amp. IC's on power supply PCB need replacement.
Part # STK392-110 sub to upgrade STK394-160E. I use Hitachi ,
no re-calls! Not advisable to use generics......
Worth repairing unless you are ready for a change......T.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
