Question about Roper FEP320 Electric Kitchen Range
Oven unit I am trying to remove the oven unit. i have it pulled out and now I can not figure out how to disconnect the wires from the old unit.
    Scholar:
  • 112 Answers
Usually, you just remove the small access panel and the wires are connected to a terminal block. You just loosen the snug screws and pull the wires out.
Posted on Nov 08, 2008
Oven shuts off with Error Code 4d21
This problem points to the controller card not functioning properly. It will need to be replaced. Here is a link so you can get the owner's manual:
http://www.manualslib.com/products/Jade-Range-Rjdo3003a-2904090.html
Check it out, it may help you figure it out.
Mar 19, 2014 | Jade RJDO3003A Stainless Steel Double Oven
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
We have a GE profile spectra (approx 8 years old), the oven lights with a boom the first use of the day. seems to light ok each time after. just started doing it a couple of days ago. any info would be...
That sound very typical of a weak oven igniter. When its cold it takes so long to get to temp.it needs to be to ignite gas so gas collects in oven chamber before igniting then as its on it get hot a bit sooner. Eventually the igniter will weaken even more to the point will it will not ignite the gas at any time, replacing it now will prevent that. The part number for the igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the igniter;
remove oven racks
remove oven door by locking hinges into place and lifting off of oven(if unable to figure how to lock hinges this step can be ommitted but it much easier with door out of the way)
remove oven floor
unscrew igniter from burner bar
disconnect wiring,which will be under storage drawer
pull out old igniter
run new igniter wiring down below to storage drawer area
screw igniter to burner bar
connect wiring
Test to see if works without booms when cold
reinstall oven floor
reinstall door
reinstall racks
I hope i have been able to help you fix your oven,
Gene
Aug 21, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I can not get the oven to come on. It is pluged in and the stove top works. The oven runs off electric and the top is both. No one can fix it and the oven does not heat up at all.
Most of the time, whn this problem occurs on ovens, it is mainly caused by the ovens thermostat. Run a test on the oven thermostat and replace it if it is faulty.
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures, transferring the wires individually from the old unit to the new.
Hope this was helpful. Thanks for using fixya.
Jan 27, 2011 | Magic Chef Ovens
Thermostat light flashing and none of the oven functions will work (fan, grill, heat etc)
  1. Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable back splash. Lift the backsplash, rest it on the cook top and remove the screws from the back splash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  2. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  3. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  4. To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
  5. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  6. To install a new thermostat, reverse the disassembly procedure, transferring the wires individually from the old unit to the new.
Hope this was helpful.Thanks for using fixya.
Jan 26, 2011 | Ovens
The oven does not heat, the fan works but no heat. The amber panel light on the front doesn't come on either.
There is a faulty component inside the unit that is why it is not turning on. The power is working fine, because it is the power that operates the fan. Therefore the panel light that is not turning on is as a result of a bad component. In order to be sure what the faulty component is i will advice that you run a test on the oven, test the oven selector switch, to test the switch,
  1. There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial.
  2. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested.
  3. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced.
To install a new oven selector dial switch,
  1. Remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached.
  2. Transfer the wires one at a time from the old switch to the correct terminal of the new switch.
  3. Check your wiring diagram to make sure all wires are on the correct terminals.
  4. Now mount the new switch to the back of the control panel and replace the cover.
Also you need to test the thermostat of the oven to be sure the problem is not from there,
  1. Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable back splash. Lift the backsplash, rest it on the cook top and remove the screws from the back splash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  4. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To replace the thermostat of the oven, please follow the steps below:
  1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
  2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  1. Reverse the disassembly procedures,
  2. Transfer the wires individually from the old unit to the new.
Hope this helped. Thank you for using fixya.
Jan 21, 2011 | Explorer Appliances B196 ELECTRIC Kitchen...
My oven will not warm up. It will just stay at 100 degrees. The gas stove works fine but the oven will not warm up to the desired heat. It worked fine 2 days ago, any suggestions.
My dear friend, i suspect the oven thermostat to be responsible for this. It is a switch that opens when the temperature of a oven is set. Therefore it is bad and cannot work according to the temperature it is set to. The thermostat is located at the control panel where a liquid filled temperature sensor bulb which senses and maintains the temperature of the oven by turning it on and off at every cycle.
First You have to test the thermostat before replacing it. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution! Since i do not know the exact maytag oven type, here is the general process for all types of oven.
  3. To install a new thermostat, reverse the disassembly procedures, transferring the wires individually from the old unit to the new.
Hope this helped you. Thank you for using fixya.
Jan 21, 2011 | Maytag Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Oven does not work and the elements are good no f codes and the probe was change?
Hello there:
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
  6. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  7. To remove the thermostat:
  8. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Jan 05, 2011 | Frigidaire Ovens
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Roper FEP320 Electric Kitchen Range Logo
80 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
