Question about JVC AV-27230 27" TV
Jvc av-27730 27"
Hi, After turning on the tv the audio works but the picture was distorted and then I turned the tv off and back on again. The screen was black with a line across, so i turned the tv off and back on again and the screen is complete black with audio working. Now there is no picture just sound. is it worth repairing
  • thenikirkfam Nov 14, 2008
    mine is very similar. I always get the black screen with the line across the middle of it. what's the solution.
  • Anonymous Mar 23, 2014
    besides the black bar, the tv makes no sound? please help
I want to known av-27730 service code
Posted on Dec 17, 2008
  • 89 Answers
There are several causes for loss of vertical deflection ( symptom: horizontal line across the screen) you might also check the electrolytic capacitors adjacent to the vertical ic. (assuming resoldering the vertical ic does not work) Some JVC sets also have a bad zener diode think its D715 part# mtzj75
Posted on Aug 06, 2007
  • 4 Answers
IN THIS SET THE FAILURE IS A COLD SOLDER IN THE VERTICAL OUTPUT HAVE THE SET TO RESOLDER THE VERTICAL OUTPUT WITH A TECHNICIAN.
Posted on Nov 01, 2006
    Scholar:
  • 68 Answers
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Posted on Oct 23, 2006
SOURCE:
JVC Model No. AV-48P575. Picture goes all distorted after it's been on awhile, then a bit later it goes back then distorted again. Can someone please help
Ur tv are developing a problems call convergence,it dying.The convergence board the 2 STK convergence ICS,and some or all it resistors are dying.These parts are must be changed to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 21, 2010 | JVC AV-48P575 48" Rear Projection...
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
No Picture, only audio
If it is a CRT TV Then The CRT Unit Could Be Dead
Aug 27, 2009 | JVC AV-20020 20" TV
My JVC AV-48WP30 picture is distorted vertically to about half the screen height. If I turn the tv on and off a few times, sometimes it will correct itself, until I turn it off again.
Try resoldering the vertical output IC that should correct the issue repeated off and on cycles often tend to bridge the solder connection causeing the set to work untill power is cut off.
May 15, 2008 | JVC Televison & Video
No picture
try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
Apr 22, 2008 | JVC AV-32260 32" TV
Ctc 195 series rear projection T.V. piture quality
Can you post a picture of what the video is doing? It shounds like a pincushion problem, but it may be convergence amp as well. A picture could clarify it for me so I would know which direction to assist you in.
Feb 23, 2008 | JVC AV-56WP74 56" Rear Projection...
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
JVC AV-27230 27" TV Logo
356 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
