Question about GE 168954 Deep Fryer
Dp18 cordset how do i find a replacement cord set for the GE 168954 fryer????? HELP ME PLEASE!
  • 1 more comment
  • Anonymous Nov 13, 2008
    lost cord
  • Anonymous Dec 21, 2008
    need a replacement dp18 cord..anyone?
  • hbpt Feb 16, 2009
    Same thing here, need a new cord set.
  • 3 Answers
SOURCE: cord
call 1-800-323-9519,Just got mine in the mail today and it works perfectly.The total (sh/handling) was 12.75.ask for the MPD-1 cord set. The letters are switched around,but its the same cord.
Posted on Jan 30, 2008
SOURCE: ge dp16 cordset
Ge customer service at 1-800-267-0516 needs to hear from enough requests and GE will refill DP16 (item#227366)power cords in stock at GE for Fryer model #168952. "There made to order with enough requests or complaints"-Cust. Serv.
So with this info, everyone please call with item number above model 168952 and state you need a new DP16.
Hope this is helpful!
Chuck-NJ
Posted on Dec 10, 2008
clyde2j2
  • 137 Answers
SOURCE: need cord
Try these URLs
www.abtecparts.com---www.marbeck.com---www.smallappliance.com---www.nelsonappliance.com
Posted on Mar 02, 2009
  • 18 Answers
SOURCE: hello - i have lost the cordset of this deep fryer
Contact Rival at the below link....
https://secure.rivalproducts.com/ContactUs.aspx
Posted on Nov 24, 2009
  • 351 Answers
SOURCE: I need a power cordset for a GE deep fryer model
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the corect cord.
Posted on May 05, 2010
Need replacement cord set (DP16)
If you have your old cord, the following will probably solve your problem.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Sep 28, 2010 | GE 168952 Deep Fryer
My ge deep fryer will not turn on
If your fryer uses the DP16 cordset, this is probably your problem. If not, find and press the reset button.
May 15, 2010 | GE 168952 Deep Fryer
I need a power cordset for a GE deep fryer model 168997.
Apr 19, 2010 | GE 168997 Deep Fryer
I need a power cord for this deep fryer. Where can I find one?
call GE customer sva for replacement parts (877) 207-0923
Mar 10, 2010 | GE 168954 Deep Fryer
I NEED A CORD- DP16 CORDSET I HAVE A --GE 168997 DEEP FRYER
appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
Dec 01, 2009 | GE 168997 Deep Fryer
Looking for a dp 16 cordset
Aug 25, 2009 | GE 168952 Deep Fryer
I need to purchase the power cord with magnetic plug for my deep fryer. GE cannot help me with this part? Where can I find a new power cord?
If it is a DP16 cord, good luck with finding a new one, but if you still have the old one, the following might help,
Aug 06, 2009 | GE Kitchen Appliances - Others
Ge dp16 cordset
Chuck-NJ
Jul 21, 2008 | GE 168952 Deep Fryer
It does not power on.
The cord is bad. We found that by jiggling the cord, the unit started to heat again. We are currently looking for a replacement cord for ours also.
Dec 17, 2007 | GE 168952 Deep Fryer
Fryer problem
The problem is with your cordset if it is a DP16, Here's how to fix it.
Oct 26, 2007 | GE 168952 Deep Fryer
GE 168954 Deep Fryer Logo
477 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
