Replaced plugs and wires replaced fuel pump relay replace fuel filter replaced fuel pump no fuel coming out of pump
Then your problem is electrical,make a tool if you replaced the relay open the cover of that relay,there you will expose the mechanical contact of the relay stick it back in its socket trun the key on and make the relay make contact the fuelpump should go on.If it does the problem will reside in the ignition switch electrical,if it doesnt check the ECM bat fuse.should be 20 amps.
SOURCE: 2000 chevy silverado 1500 4.3 eng
More than likely its a bad termianal connection on top of the fuel pump. Its a comon with chevys'
SOURCE: fuel pump fuse
replace fuel pump /fuel filter/screen/keep enough gas in tank at least 1/2 tank of gas at all times and change gas filter at 10,000 miles
SOURCE: 1997 chevy silverado 1500 350 vortech, new fule pump not working
before you drop tank again, check fuses & relay.then disconnect fuel line @ filter turn key to on position should hear fuel pump run and get gas stream out of line. if no flow from line new pump faulty be sure & remove negative battery cable first good luck.
SOURCE: having problems with chevy s10 replaced fuel pump
Check the cable that goes from your battery to the fuse box the relay that is clicking is on. Check for lose bolts or corrosion of the contacts or something like that. If the relay is clicking it sounds to me like it is a voltage issue going to the relay.
SOURCE: i am not getting power to my fuel pump
on a lot of ford products there is a switch that goes from the fuel pump to the inside of one of the bedsides.
what this is, is a shock switch that turns the fuel pump off if it absorbs a hit.
its a really dumb safety feature but its effective.
there is a red button on it that u have to press to make it active again.
sometimes they just trip for no reason.
