Question about Whirlpool GHW9100L Front Load Washer
Control light blinking on/off
Held button four to ten sec. and light remained on, bliinking on/off washer controls will not work?
  • 370 Answers
Did you hold the end of cycle signal? if not try that.
Posted on Nov 19, 2008
I have problem with remote control, my remote control gives me blue light to switch the dashboard on but there is no lights coming on the dashboard. what is the problem
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Mar 09, 2015 | 2006 Tata Indica LSi
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
How do i change the numerical code?
How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
1. Program using the "Learn" Button
2.
Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Control lock light will not go off on duet
there is a button marked "control lock" hold for 3 secs and will release, its the far most right bottom button
Nov 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Whirlpool GHW9100L Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
