Question about GE Slim Spacemaker 7-5295 CD Shelf System
Error nd after entering cd and pressing play
The Cd player makes a funny sound showing cd and after a few seconds the nd shows where cd was. Nothing is playing on the cd player anymore. We have tried cleaning the drive but that did not help. What is wrong with our player??
  • 2 more comments
  • Michael Hayden Oct 26, 2006
    Thanks, but I have already tried to clean the lens. I still get the same output.
  • Anonymous Nov 21, 2007
    Same exact issue as mikehayden. Would love to have a solution to this, as GE does not support this equipment any more.
  • spettyjo Nov 27, 2007
    I recently reinstalled my spacemaker. We were just moving in from room to room if we wanted to use it. But, like the others, the cds won't run. They turn, but the screen shows nd. Have anyone figured this one out yet?
  • EddieH Dec 09, 2007
    Input CD and uint's display indicates "cd" for about 30 seconds then displays "nd" and does not play CD.
    Novelist:
    Champion:
  • 275 Answers
Have you tried cleaning the Lens? nd means No Disc, indicating that the Lens is not picking up the signal, and so is indicating a 'No Disc'
Posted on Oct 24, 2006
1. Press Open/Close to open the drawer and insert CD
2. Press Play/Pause and wait over 30 seconds or more for the CD to start playing.
3. Use only original CD, not copies.
Posted on Oct 15, 2008
The solution is to never buy another GE product of any kind. They have been completely unresponsive on this one, and they don't get any more of my hard-earned money.
Posted on Dec 02, 2007
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
Cd player doesn't play.
If you are using a pirated cd or self compiled cd, chances they don't play. try the original cds
Jun 26, 2009 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Cd player keeps showing nd cannot play any type of Cd at all
Hi Tony,
Your GE 7-5295 keeps showing nd (no disc), this simply means that your lens has been damaged. Please replace the lens and you would enjoy listening to music once again in your kitchen.
Kind Regards
May 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Apr 17, 2009 | 2002 GMC Envoy
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
GE Slim Spacemaker 7-5295 CD Shelf System Logo
374 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
