Question about Dremel Variable - Speed Multipro Rotary Tool 395
I need a coupling
For Dremel cordless drill model 850
  • 2,176 Answers
Call Dremel at 1-800-275-2052 and they can help with parts and schematicsHope this helps. Dave
Posted on Dec 24, 2008
Exctly what fits what
Go to Amazon and do a search for "dremel drill chucks". There are a variety of models that will close down to '0' to allow use of bits as small as #80. Make sure and look at the low end capacity and make sure it will go small enough for the size bit you want to use. I have used to #4486 to use micro drill bits but it is not rated to go that small and can cause wobble and break the bit if not very careful. They are pretty cheap so you can try a couple different models even.
Aug 10, 2014 | Dremel 3000-2/28 2 Attachments/28...
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Where can you find a Dremel model 780 battery
I'm not sure why but, the Dremel 9.6 volt battery is only available through a Robert Bosch retailer or authorized service center. Their homepage is at www.boschtools.com/Pages/default.aspx where you can search for the nearest service center under the 'Service' tab.
Jul 12, 2012 | Dremel Drills
Dremel won't switch off , have had to remove battery to stop it.
Either the switch is defective (most likely) or there is a short (less likely).
If it is still under warranty contact the manufacture or the place you purchased it.
If not then you might dismantle it and check the switch to see if it is defective. Use a volt/ohm meter to check for continuity as you toggle the switch. Also check for shorts in the wires or where the wires connect to the switch.
Jun 27, 2011 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
I bought a dremel 4000 on ebay and it didn't have a manual with it - I need basic instructions to use the drill bits I purchased that go with it. Is there an adaptor that I need to use them?
Your drill bits side, should have a twisting hand tightening head into which you insert the bits, and have fun. If this is missing, you can either buy it, at dremel stores, or get a nut of the same thread and get the job done.
Sep 07, 2010 | Dremel Drills
Did not receive manual in my box, for Dremel Driver 7.2v model # 1120-01, how could I get a copy. thanks mark
go to Dremel.com and they can get you one if they are not available online at that site.
Jan 20, 2010 | Dremel Drills
Type of dremel to use for computer case modding
Dremel may not be the way to go. ABS and poly plastic likes to melt and ball up on a Dremel
Nov 20, 2017 | Dremel & Stylus Lithium Ion Cordless...
Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dec 23, 2009 | Dremel & Stylus Lithium Ion Cordless...
I cannot get the chuck to tighten the collet
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
May 29, 2009 | Dremel 750 02 Minimite Cordless Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
518 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
