Question about Sony PlayStation 2 (PS2) Console
Black screen, no disc spin or eject, fan spins
Hello when working inside my fat Ps2 to remove a jammed disc i accidentally pulled the fan connector from the motherboard and subsequently lost the connector. When the console was reassembled it worked perfectly except for the fan. So i disassembled the console again and soldered the wires from the fan back to the motherboard. When the console was reassembled and turned on i have this scenario: Fan spins, black screen, no audio, disc not spinning, disc tray won't open, blue light not on, green light on. Reset button works but eject doesn't. Did I short something out or fry something inside?
  • rjsicka Dec 17, 2008
    when i turn on my ps2 the green light comes and the fan spins but the blue light does not come on.
  • Anonymous Mar 30, 2014
    you can hear disc trying to spin put stops also what is the battery inside the console for
That same thing happened to me. I disassembled the ps2 to find out the problem, I found out. If your console does not turn on or no lights check the silver ribbin connected to the reset button. See If it is in all the way the top and the bottom of the ribbin or check to see if there are any tares in it if there is replace it . You can get good parts off of Ebay.
Posted on Dec 04, 2008
Crunching sound after disc inserted and it starts spinning. then screen reads "error occurred, eject disc..."
there mite be something jammed inside the disk drive take a look inside to see if theres anything inside if so just pull it out with something long and thin that dosnt conduct electricity.
Dec 20, 2009 | Nintendo Wii Console
On switch button turns green and immediatley turns off again. My disc in the beggining stoped spinning eventhough i can here it trying to spin
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
Nov 11, 2009 | Sony PlayStation 2 Slimline Console
Disc wont spin
There are 4 reasons a disc won't spin on the Slim PSP. The most common is a failed laser.
1. Failed laser -- the disc will not spin up to speed, or not spin at all, due to a bad laser. If you close the PS2 with no disc inside, the ps2 will never spin the disc. If you chose the PS2 with a disc inside but a bad laser, it still thinks no disc is inside and will not spin.
2. Lid closed sensors. There are two of them. One on the motherboard and one on the reset switch. These sensors let the PS2 know that the lid is closed. If one or both of these break, the disc will never spin because the PS2 will think the lid is still open.
3. Damaged case. If the case of the PS2 is damaged, the two parts of the lid that are supposed to press the lid-closed sensors will never press them.
For more information, pictures, and parts, click into the following page:
http://store.richspsxparts.com/slpsnospdi1a.html
Oct 21, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slim not reading discs
You can buy new DVD pickups online for about 15-20 It will take a very small phillips screwdriver and needlenose pliers to change out the old one
Mar 22, 2009 | Sony PlayStation 2 Slimline Console
PS2 won't work at all
The laser or main power unit might of died i would just go buy a new one there not that much and these problems will probaly run u more than the new one.
Jan 12, 2009 | Sony PlayStation 2 (PS2) Console
HELP! PS2 Fat
don't worry that one is easy
if you'll check the disc tray side you'll see a white slot where the ribbonwire should connect you'll also find some connectors colored pink green and white if you'll look thoroughly it is located beside those connectors
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
Disc won't spin after replacing laser
Have you replaced the laser yourself? before installing it you should remove a soldered joint on the laser, it is just like two points soldered together, just desolder that and put it back, it will work. Good luck
Feb 02, 2008 | Sony PlayStation 2 (PS2) Compact System...
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Makes Sounds and Keeps Pausing Games
Hi Ebridges2,
The Game your playing is probably a Blue colored media.  That is ones that spin so fast.  You console has become dusty and loaded with lint probably.  You can open the case and clean up the insides. Also while your in there, remove the ocver and polish up the lasers lens.  This will probably get you back in business. If you do nto have success, contact me at Repairtech@ playstationclinic.com   I run The Playstation Clinic at www.playstationclinic.com  If you have a Slim Model it will cost more than the big model to repair.  The slim model is $41 full refurbish including return shipping inside the USA.  The big Fat PS2 Versions are $36 including return shipping.
Oct 14, 2007 | Sony PlayStation 2 (PS2) Console
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Jun 09, 2007 | Sony DAV-FR10W System
Sony PlayStation 2 (PS2) Console Logo
216 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
