Question about Garden
Craftsman chainsaw ps00376 2.0 cubic inch oil/gas ratio
We borrowed a craftsman chainsaw ps00376 2.0 cubic inch and we need to know the oil/ gas ratio please? email is
  • 52 Answers
Hi rbv1222,
40:1 is the ratio.
40 parts Gas to 1 part oil.
3.2 oz of oil per gal gas.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Posted on Nov 09, 2008
Need to know the oil mix amount to the gal
The oil to gas ratio is 40 to 1. If my math is still good this works out to 3.2 ounces of oil to one gallon of gas.Hope this helps and thank you for letting me help.
May 13, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need gas/oil ratio for Husky 350. Thanks
50:1 is the correct ratio. Be sure to shake the fuel can just before filling each time to prevent oil starvation. Don't make up more than a gallon at a time unless sawing is your business. Always use fresh fuel and a modern synthetic saw oil. Hope this helps!
Oct 18, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Need ratio for craftsman gas line trimmer
i think the mixture is 50:1 50 petrol and 1 oil
Jul 21, 2010 | Craftsman 25cc Gas Line Trimmer
Oil & gas ratio for an older Craftsman chainsaw?
Unless the saw is over 40 years old, 40:1 ratio will work well. Really old saws required 30/32:1 ratios when petroleum based oils were used. Be sure to premix the fuel and a modern synthetic saw oil in it's own can and be sure to shake thoroughly just before refueling each time. Check the H jet setting by warming the engine up, then pull the throttle full on. Proper adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Be sure to check the fuel filter, air cleaner and muffler for plugging before making any jet adjustment. Hope this helps!
Jun 26, 2010 | Garden
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Oct 26, 2009 | Garden
Gas mix
ok buy the cheap gasit does not need the high price stuff 1 gallon of gas and 1 small bottle of two cycle oil. thats all you need
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
May 13, 2009 | Craftsman Garden
Garden Logo
1,019 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
