Blower on the front ac works but the ac kicks on and off. the rear ac works good
SOURCE: 2004 Dodge durango-blower not working
the blower is the same for front and rear. you have a blend door problem look by your feet on drivers side just under dash there is a slide mechanism that breaks.
SOURCE: I have a 2001 dodge
I would have to say the resistor also. Cheap part and the labor is free when you do it yourself. It should be located behind your glovebox.
SOURCE: 2005 Dodge Durango Front AC won't blow cold, back air works great
Did anyone find the answer for this?
SOURCE: Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Testimonial: "Great thanks that could be my problem. Is the motor by the inside coil"
