Question about Whirlpool Refrigerators
My refrigerator can not restart automatically. That is say, it can be restart manually by on/off switch, but it will stop after few hours.
    Guru:
  • 93 Answers
I will be more than happy to help you out with this.  Read this Article on Restarting your Frigidaire Refrigerator.   If you have anymore questions after reading the aricle, you can find me on Frigidaire Technical Suport.   Thanks,
Bill
Posted on Nov 08, 2008
Freezer stops working every week or two and hear loud buzzing. unplug and for few hours and starts working again
The buzzing is probably the compressor or condenser fan trying to run. When you switch it off it cools down and restarts when you switch back on. Next time it happens see if you can pinpoint the buzzing and let us know,
Jul 15, 2015 | Refrigerators
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
May 13, 2015 | Liebherr CS1601 (15.5 cu. ft.) Bottom...
My viking under counter refrigerator freezes all liquid
Is it a digital temp. display? Does this show a low temp? It should show +/-34 degrees. Listen if the compressor runs continuously. It should run for a while and then switch off. When you change the temp setting, as you turn it down, the compressor should stop. If it runs continuously then the likely cause is a stuck/faulty thermostat.Before replacing this, switch off and leave open until unit is at room temp. Then switch on again and monitor. If the thermostat if faulty and the compressor runs continuously you can damage it by overheating. The compressor will run for a good few hours after restart, until set temp. is reached and then switch off automatically. Good luck!
Nov 14, 2013 | Viking 24" Custom Panel Undercounter...
How do you manualy defrost?
Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost, simply push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart automatically when defrosting ends. Empty water from the drain pan after defrosting.
Jun 18, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
The right side of the fridge is not cooling well. the freezer is fine, but it also making a strange noise
Hi and welcome to FixYa, I am Kelly.
That strange noise your hearing is probably the fan blades of the evaporator fan striking ice build up on the evaportor coils. This symptom is typical of and automadefrosting problem.... or someone left the freezer door open for a very long period.
You can try doing a manual defrost by unplugging the unit and place a fan blowing into the freezer compartment / compartment making noise for about 2 hours. (makes a water mess) After 2 hours tend to the water mess and restart the unit. Most likely the noise you heard will be gone... for a few days. If you have an automatic defrost problem the noise will return in about 72 hours as the ice build up gets larger on the evaporator coils.
Depending on date of manufacture this unit can have either a manual defrost timer or an adaptive defrost control board that controls the automatic defrost. .
Thanks for choosing FixYa,
Kelly
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice maker is switching itself to clean mode. I have to push stop ...wait a few minutes and switch it back to "ON". It is doing this quite frequently. In addition, once it is switched back on, the water...
hi my name is mark, sounds like the clean switch is sticking. does this unit have a membrane in front of switch. switch might be wet. also you might let the clean time out, then restart unit.
Feb 04, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
My six month old Samsung fridge freezer stops freezing. But if I switch it off at the wall and wait a few minutes it works again. But then stops freezing again. So I switch it off at the wall for a few...
There is a possibility that you have a problem relating to the internal refrigeration system. It may contain moisture contamination which freezes in the refrigerant feeding device. Shutting it off allows the moisture to melt and restart the circulation of refrigerant. This problem can only be solved by a certified refrigeration technician.
Making sure the condenser is free of dust and dirt will improve the ability of the system filter/dryer to absorb and hold moisture.
Jun 03, 2008 | Samsung Refrigerators
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
941 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
