Question about Intel Motherboard
Motherboard Manual JFP1 Connector
I went and looked at the FixYa manual page for this model, but didn't find the info on how to connect the JFP1 (motherboard to case) wires, could you please help me on this one...and I think it's just great that there are people out there, understanding that not everyone can afford (financially that is) to purchase information on the Net.
Thank You,
Pierre..
frizimus2@hotmail.com
  • TUGZ69 Mar 26, 2009
    JFP1 /MS6340 VER1
    President:
  • 2,351 Answers
Hi Pierre,
Though many MSI boards are similar, it would help if you would include the model number of your MSI board?
(Many times Fixya does not show your current correct model number but you can add it into your posted question). The pic's included below belong to the MSI K8N Neo3MB.
Look to page 2-16 (In manual). What is not included in the manual are the wire colors. Case wire colors do vary from case to case.
The colors: red, blue, green, light blue, light green & light red are commonly ( + ) = positive. The colors white & black are commonly ( - ) = negative. Some case wires-connectors are marked +/-, some are not marked. (The common color of each set of case wires is usually ( + ), positive)!
If your board is not like the pic's above than include your model number & I'll adjust my answer.
Good luck Pierre!
Mike
Posted on Nov 08, 2008
  • Mike Peluso
    Mike Peluso Nov 08, 2008
    JFP2, (Do Not) connect the power led here. Connect the power led onto JFP1.
    JFP2 is for the internal speaker.
K9n6pgm2-v pin out
MSI Support > K9N6PGM2-V motherboard > Main Support page,
http://www.msi.com/product/mb/K9N6PGM2-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down list click on - Manual
Now click on the blue -> M7309V1.2.zip
Click on the country name nearest yours.
A small window will come up on the right -
Opening M7309v1.2.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not left-click once in the small empty circle, to the left of Save File
Now go below in the window, and click on OK.
A small window will come up on the left. Allow the file to download all the way.
Now DOUBLE-click right on the file name.
In the next small window go to the left side, and click on -
Extract all files
At the bottom of the next three small windows, left-click on
Next, Next, and Finish.
In the last small window go to the file name next to the red Adobe PDF icon, and DOUBLE-click on it.
7309v1.2(G52-73091X3)
There is your motherboard manual in PDF file form.
( Plus + icon increases the view size when you click on it.
Minus - icon decreases the view size.
When I refer to a page number it will be for the PDF reader, and not the actual manual's page )
Go to Page 8.
Motherboard Layout
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
JFP1 is the Front Panel header.
JFP2 is an additional header. To be discussed after JFP1.
JFP1 is on the Right/Bottom corner. It is placed Vertically.
(Parallel to the right bottom edge of the motherboard)
Above it's left corner is JUSB2. (Front Panel USB header 2)
Above JUSB2 is the SATA2 connector. To the left of the SATA2 connector is the SATA1 connector.
To the left of the SATA1 connector is the CMOS battery.
The contact pins are arranged in two columns.
4 pins on the Left side, 5 pins on the Right side.
Go to Page 14. JFP1 pinout, and JFP2 pinout, is at the Bottom of the page.
JFP1:
Starting on the Bottom going towards the Top, Right side;
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going towards the Top, Left side'
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. (Probably 5 Volts positive, and used by the factory only)
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
IF the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
JFP2:
Below JFP1 is a header that is placed Horizontally. It is parallel to the Bottom edge of the motherboard. This header with 13 pins in it, is the JLPC1 header.
(Starting on left side at the Top row; 4 pins, no pin, 2 pins.
Starting on the left side at the Bottom row; 7 pins)
To the left of the JLPC1 header is the JFP2 header.
4 pins across the Top row, 3 pins across the Bottom row.
The top 4 pins across the top are for an internal speaker. Used to hear BIOS Beep Codes.
Starting on the Left side coming towards the Right, top row;
No indication of polarity.
Believe pin 2 is for the Positive wire, and pin 8 is for the Negative wire.
Starting on the Left side coming towards the Right, Bottom row:
Pins 1, 3, and 5.
These pins are ONLY used for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED.
(One example; Green Turbo, Yellow normal)
The rest of the pinouts are listed in the manual.
Have additional questions? Post in a Comment.
I also downloaded the manual.
Regards,
joecoolvette
Oct 16, 2012 | MSI K9N6PGM2-V Motherboard
What number is the pinout for 915glm-v where does the power switch go
Here is the link to the location you can download the manual for that motherboard. You will ahve to select your download area but it is a small download and it will show you the exact location of all the wiring connectors.
http://www.msi.com/service/download/manual-4378.html
You want to look at page 8 at JFP1 position. The power button connects to to JFP1 pins 6 and 8 according to the book.
Oct 27, 2011 | MSI 915GLM-V Motherboard
Emachine W3410,the main three wire from the motherboard to the power botton on and off switch was remove and iam not sure wish pin they go to .power led, power sw, H.D.D.led,
The eMachines W3410 uses an MSI ms-7145 motherboard.
Also known as RS480M
This is MSI Support, and the download page for the motherboard manual, for the RS480M motherboard,
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=204
To the Right of the photo of the motherboard, you will see a gray bar with, BIOS, Driver, Utility, Manual, and RSS.
Left-click on Manual.
On the next page look under the heading to the right - Document.
Left-click on the blue - E7145v2.1.zip
On the final page click on the country nearest yours.
A small window will come up with the heading -
Opening E7145v2.1.zip
Be sure that Save File has a green dot, in the empty circle to the left.
[If not, Left-click on the empty circle to the left of Save File]
Now click on OK, below.
Where this file will go.
If you Do Not, have your documents set to save to your My Documents folder (Documents for Vista), the file will go to your desktop screen.
In either place Double-click on the file. Now go up to the left, and click on - Extract All Files.
Click on Next, and Finish.
You will now see a PDF icon. Double-click on this icon.
Go to Page 15.
The plastic panel on the front of your computer is the Front Panel.
This is where the Power On switch, Power On LED, and HDD LED are located.
The connector on the motherboard where the cables (Wires) attach to, is the Front Panel header.
The front panel header is a series of pins, sticking up out of the motherboard.
The MSI ms-7145 motherboard, (RS480M) has the Front Panel header separated into two headers.
JFP1, and JFP2
Looking at the motherboard with the Processor socket to the top, and the Ram Memory slots to the right, the JFP1, and JFP2 front panel headers are located at the extreme bottom Right, of the motherboard.
[Use the Zoom In feature (+ at top of file) to enlarge the motherboard layout on Page 15]
Now go to Page 38.
Page 38 shows the connections for the JFP1, and JFP2 headers.
The JFP1 header, and the JFP2 header, consists of two rows of pins in a horizontal column.
The pins are arranged parallel, to the bottom edge of the motherboard.
Right above the JFP1, and JFP2 header may be three pins, with two of the pins have a jumper. We will not concern ourselves with this jumper header (BIOS with Protect Jumper)
The JFP1, and JFP2 headers are close together. There is no separation in-between them.
The JFP2 header is for an internal speaker.
The JFP1 header is for the Front Panel cables.
The JFP1 header pins start from the right side of the motherboard, and go towards the left.
There are 5 pins across the Bottom. (Going from right to left)
There is NO pin, then there are 4 pins across the Top.
(Again, going from Right towards the left)
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting on the Right side, going towards the left for the Top row of pins, the pins are numbered,
10 (NO pin for 10), 8, 6, 4, and 2.
Starting on the Right side, going towards the left for the Bottom row of pins, the pins are numbered,
9, 7, 5, 3, and 1.
1) Pins 2 and 4 are for the Power On LED.
2) Pins 6 and 8 are for the Power On switch
3) Pins 1 and 3 are for the HarDDrive activity LED
4) Pins 5 and 7 are used for a Reset switch. (If applicable)
5) Pin 9 is not used.
Apr 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
NEED MANUAL FOR CONNECTORS "JFP1" AND "JFP2"
You can download the manual by clicking this link:
http://download3.msi.com/files/downloads/mnu_exe/M7104v1.0.zip
The connections for JFP1 and JFP2 are given on page 13 of this manual.
Hope this solves your problem. Thanks for using FixYa
Dec 23, 2009 | MSI PM8M-V Motherboard
Need help on connecting up motherboard to rest of pc
I downloaded the PDF Motherboard Manual for the MSI MS-6380E Version 1.0, just now.
Let's take a look at that JFP1 header.
This view is looking at the JFP1 header, sitting at the bottom right of the motherboard, TO THE LEFT of the JFP2 header. The JFP2 header is at the very bottom right hand corner. The JFP1 header is just to the left of it. The processor is to the Top/Middle.
Looking at the pins going across the top of the JFP1 header, they are as follows,
2, 4, 6, 8, and there is no 10. There is no pin for 10.
Looking at the pins going across the bottom, they are as follows,
1, 3, 5, 7, and 9.
Pins 6 & 8 are for the Power On switch.
Pins 2 & 4 are for the Power On light, (LED light)
Pins 1 & 3 are for the HarDDrive activity light.
Pins 5 & 7 are used for a Reset switch. (IF, you have one)
Should you not have the Motherboard Manual, go here,
http://motherboards.org/mobot/manuals/MSI/MS-6380E/
(If this doesn't come up as a link, copy and paste it into your address bar, then press the Enter key)
On this page click on ->Download <- to the right of
File: 6380ev1.0.exe Version: - - Release Date: - -
When you do a small window will come up. Click on the empty circle to the left of -> Save.
This file will be saved either directly to your deswktop screen, or your My Documents folder. I don't know how you have your downloads set up to be saved. I save them to my My Documents folder.
Once you see this file, double-click on it. It's a WinRar file. There will be a Microsoft 'Squawk Box' that comes up. "Warning this publisher could not be verified, ya-da, ya-da"
Ignore it! Click on -> Run
Now the WinRAR extraction archive will come up.
Click on Run.
Now go to the PDF file and double-click on it.
There's your Motherboard Manual.
Apr 12, 2009 | MSI KT3 Ultra Motherboard
Pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
http://global.msi.com.tw/index.php?func=searchresult&keywords=K7T+Pro&table=download
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Mike
Jan 19, 2009 | MSI MS-6330 Motherboard
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
Apr 23, 2008 | Intel Motherboard
How do hook up front panel power switch to motherboard
The simple way is to remove the front panel of the computer trace the wires to the front panel leds, make note of color pair to each led. The using the manual that came with the motherboard locate the schematic for the JFP1 connector on the motherboard, it show's where the leds wires connect to operate. If you have no manual, if you look very closely at the connector you will see where the led wires connect, you may have to use a magnifiying glass and flash light. You cannot damage anything if you accidently place the led wires in the wrong place. If the panel led wires are in a single connector and won't work on the motherboard, you can remove the wires from the connector by using a very small sharp pointed pick to push down the retaining tab on each wire, thus enabling it to be removed from the connector, just be patient. BPCS
Dec 31, 2007 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
10,158 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
