Question about Logitech Webcam
Logitech webcam and yahoo messenger
I have logitech cam and yahoo messenger says it does not dtect it. I have already tried the H-Key User (VFW) (1) thing to no avail. It worked with yahoo ar first then stopped. I use this cam on Live Mesenger and on Paltalk, etc., etc. I have XP. I think the problem is with windows service pack 3. Please help me!! :):)
  • 97 Answers
Ok try to uninstall yahoo messenger and reinstalle it ive had the same problem once before
Posted on Nov 09, 2008
The other person on Yahoo is not able to see my images on my logitech webcam? I am also not able to see anything on my logitech webcam when I am on Yahoo...
HI there after login in yahoo messenger go in messenger > Preferences> webcam> select device from there & save it. After that invt other for show your cam. Thanks.
Mar 15, 2010 | Logitech Quickcam Chat Webcam
Frozen video on calls
Try putting the camera under VFW (Video For Windows) control - it involves a registry edit and can be found here
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamfix.html
It didnt work for me at first - I had to download the windows amcap as well. VFW doubled my fps
If you open the 'webcam' menu on the webcam picture frame and also open 'Statistics' you can monitor the f/p/s during transmission - Generally try and keep the frames per second above 1.0 fps to prevent freezing. I transmit the 'small image' with my contacts and they zoom up to 200% -all on the webcam frame menu. When you open 'Statistics' you can tell if you are on VFW control - it will say VFW along the lower panel.
I also increased my virtual memory following an error message.
Sep 28, 2009 | Logitech QuickCam Connect Webcam
My MSN freezes eveytime i go on webcam to somebody.
Sounds like a conflict or resource problem
1) Try downloading a new browser and run it without add-ons or plug-ins
set it to default and then try msn
2) I am more Yahoo than msn and one way to prevent this in Yahoo is to put the webcam under VFW control
try visiting this page - must be with IE !!
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamtest.html
This action makes a registry change - It increased the frames/ per/ second by 100% for me
3) Increase your virtual memory
4) You do not say if you are on dial-up, if you are I strongly recommend upgrading to broadband. Internet connection via mobile phone can be pretty fragile as well.
Aug 25, 2009 | Logitech QuickCam Connect Webcam
Webcam doesn't work with yahoo messenger
You should un-install yahoo and re-install it , you won't lose any of your contacts ....this in turn will eliminate yahoo as the problem . let me know .
May 30, 2009 | Logitech 961462-0403 Webcam
Webcam broadcasting but only shows black screen
i have a logitech web cam. i want it's drivers
May 29, 2009 | Logitech Webcam
Need software for Logitech quickcam to access yahoo messenger
http://www.logitech.com/index.cfm/support_downloads/downloads/ aLL drivers are here just download n install.RICHARDM69
Dec 13, 2008 | Logitech Webcam
Black screen in Yahoo messenger
Hi ,
Make sure you installed your logitech driver. Ifyou have installed it already might want to unistall and reinstall it . Install the software frst.
If you may have additional questions pls feel free to ask
Cheers
Jun 28, 2008 | Logitech Webcam
Yahoo messenger - Webcam is not connected
You cannot access camera source until the webcam is running in Messenger - try setting it up from scratch
1) The webcam is working outside of Messenger
2) Reboot webcam by unplugging the USB connection and inserting it again - its important if its been used elsewhere and prior to chat.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger CONNECTION
Open messenger - on top toolbar > messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the 2 lower boxes > apply > ok TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch. DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections about who you will allow to view you
IN USE Your contacts may need to configure their connection the same as above or they may also get a "webcam not connected" message
Jun 16, 2008 | Logitech QuickCam Express Web Camera
Pic on yahoo messenger chat
on yahoo you have to select the cam
select messenger > preferences > webcam and select source
Dec 08, 2007 | Logitech QuickCam Pro 4000 Webcam
Logitech Webcam Logo
90 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
