Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Cozy heater i cannot get the pilot to stay lit and i just put in a new thermocouple-a piece fell out if the pilot gas orfice when i took the pipe out-where does it go? oops doug fulwider olympia,wa
    Problem Solver:
  • 10 Answers
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Posted on Feb 05, 2009
Thermocouple is putting out over 17mv and the pilot will not stay lit when released
Gas flow to pilot orfice may need adjusted up.
press the helpful button and check out link below
Gas furnace pilot light operation
Jan 10, 2016 | Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
I have an Atwood 6gal hot water heater with a 37c14u-5 controller. The pilot light will not stay lit. I have replaced the thermal coupler twice and the pilot tube with orfice once. It's still not...
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Pilot light keeps going out
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
The pilot light will not stay lit. A new
Try cleaning the orfice for the pilot light. You will have to dis-assemble the fuel lines from the thermostat to the burner to get at it. The orfice has an extremly small hole in it, do not make it any larger, just clean it out.
Mar 14, 2010 | Drills
Pilot won't stay lit when button is released
Thermocoupler is dirty or needs replaced. The thermocoupler is the copper looking tube that runs along the pilot tube. The flame has to hit the thermocoupler to generate milivolts to open the gas valve
Dec 31, 2009 | Cozy (W352E) Heater
Pilot won't stay lit I have changed the thermo coupler
Make sure the thermocouple is in the pilot flame,if it does not stay on after that,replace the regulator.
Nov 16, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Cozy heater
Make sure the gas valve is turned to the "On" position after the pilot stays lit. You may need to replace the thermopile. Some units have a thermopile rather than a thermocouple and it will not allow the gas valve to open if not enough voltage is being sent to the gas valve. Hopefully your gas valve is working properly and will not need to be replaced.
Dec 04, 2007 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
169 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
