Question about Kenmore 22422 Top Load Washer
Sounds like an airplane taking off!
We have a Kenmore washing machine model number 22292...it is a top load and as soon as it is done with the spin cycle and is going over to the rinse it shakes violently and sounds as if it is an airplane trying to take off! The clothes are level in it. It only does this at the very end of the spin cycles.
Any idea to what it is and how we can fix it ourselves?
  • 63 Answers
Check your drive block under your agitator if metal shavings replace
Posted on Nov 12, 2008
Top loading Kenmore h e washer roars while spinning
kind of hard to solve without more info.but it could be unlevel find a level or borrow one and place on top of washer.make sure it reads between bubble on level.check both sides on top of washer.if you hear kind of grinding noises and shifts hard it could be transmission..
May 26, 2014 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series washer wont drain or spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2010 | Kenmore 22422 Top Load Washer
When my Neptune top loading machine is spinning out it sounds like an airplane taking off and can even be heard upstairs. Of course, I got an extended warranty and two months after the expiration date I...
If it's a FAV6800A or FAV9800A you could have Outer Tub bearing issues brought on by a Tub Seal leak.
Have you had any unbalance error codes such as dC or uC in the past?
Open the washer lid and spin the wash basket as fast as you can in the CCW direction the Spin cycle direction do you hear metal against metal sounds? Does the wash bsket coast down after several revolutions to a slow stop?
If it's Outer Tub bearings this is a big job but can be done by anyone who is handy and some direction. What are the first two digits of your machine serial number found here;
The range is 10 thru 17......
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.......Rich
Jun 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer won't stop running.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This sounds like a Timer problem. See the following Whirlpool / Kenmore Service Manual for top load / direct drive washers. It has a troubleshooting section and test procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Apr 06, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer sounds like a plane taking off while spinning...
yes the rear bearing is gone,,you may have caused the issue by using the wrong soap,,in a front load you must use he soap only,,,the cost to fix 500.00-700.00
http://www.washerwizzards.com
Dec 24, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Kenmore top load 22292
Check the lid switch. Listen for the clicking sound when you raise the lid. I have found them just loose or out of alignment on some. reply back if you need more help.
Nov 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Kenmore 22422 Top Load Washer Logo
195 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
