Question about Sony Playstation 3 (PS3) Console
Ps3 Stuck on wave screen, please respond, i would appreciate
Hey man, sure you get this all tha time, but its stuck on the first screen/ wave thing... I tried to reset the resolution? now its not coming up at all, just black screen any ideas yoda?
  • 95 Answers
The "NO VIDEO" problem is all too common. It results from overheating of the RSX and/or CELL processor. It is necessary to disassemble the unit apply AS5 compound and shim the heatsinks to ensure proper contact between the heat sink and the processor. I do this for $65.
Posted on Nov 11, 2008
I attempted to update the system from a game and now it's stuck. when i turn it off its just starts the update again and every time it gets stuck on 99% and it just stops. i tried getting to the restore...
If the power button hold doesn't work...try this...,
Take the clip out that holds the drive. Take the screw out but leave the drive inside.
When the update begins, pull your drive out. You will get an error message and it tells you to restart your system to try again. Instead, let the time run out, and your screen will go blank for about 30 seconds until it starts back up telling you that you need to reformat the drive. (If you don't get this message after 30 secs the first time, YOU HAVE TO REPEAT IT till it does. Then put your drive back in again making sure your controller is plugged in (wired in with USB) and press the PS3 button on the controller. It will then ask you to either press start and select at same time OR PS3 Button PRESS START and SELECT. Do not agree to any user agreements!! Make sure you hit cancel and it will reset to the startup screen.
* Just wondering....did you recently open your ps3?
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Downloading ps3 update and I'm stuck on a error loop
hey mate!
i had the same problem as you have with a 40 gb model i bought with a ylod and fixed. after i assembled it i tried to update the firmware but it got stuck in a loop between 69 to 70 % and wouldn`t finish the install. after doing some research i found out the the error number that appeared (cant remember the number now) happned because some hardware wasn`t connected the way its suppose to,when 69% will indicate the blu ray drive,and indeed i noticed that the clip on the ribbon was broken . i had to use a piece of cardboard at first to shove it right to its place nice and tight and started the ps3 again , (failed again because my wifi antenna wasnt connected, but after i connected everything...) the update finished and i was a happy man!
so if your ps3 have been opened in the past , there is your problem.
hope i healped and good luck!
Jan 08, 2010 | Video Game Consoles & Games
Stuck at the loading screen
it could be your disc, try cleaning it with a cloth and reinsert it
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is stuck in the update.
pull plug let sit for 30 min and plug back in. that gives it a chance to reset the hardware
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 tuns on but no homepage and controllers not responding right
Check out #3 on my 5 common problems with the PS3.
Just google my username.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is stuck on the wave screen
I dunoo, but ur PS3 has gone bad for sure, if its under warranty Sony will fix it for free.
Mar 23, 2009 | Sony PlayStation® 3 (80GB) Console
My ps3 gets stuck on the wave screen
This is usually caused by one of two things:
1) If the wave is still moving but you do not get a menu, then it is most likely the hard drive is having problems. Try taking it out and booting the system to see if it continues past the wave screen...then you will know for sure.
2) If the wave is not moving (frozen) on the screen, then it is probably a problem with the GPU and will need to be serviced.
If it is under warranty, I would send it in. Taking out the hard drive will not void the warranty, but taking apart the console will.....Hope this helps...
Retrohack
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 gets stuck on wave screen no logging menu help
Retrohack
Nov 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 crashed .... plzz help
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i afrikaans BUT PLZZZ RATE ME.....please rate thans
Jul 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
224 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
