Question about Waring WMK300 Professional Belgian Waffle Maker
WMK300 turns on but doest not heat up
My WMK300 turns on but does not heat up. The power light glows but the ready light never turns green.
  • Anonymous Jun 29, 2008
    My Waring Pro heated up during my steam clean. I like to prep my iron by steaming some water before I spray it to cook with. The green light came on breifly, and the iron simply continued to cool down.
    Scholar:
  • 71 Answers
The problem is an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
Posted on Jul 30, 2008
I have the same problem. I had the waffle iron for several years. It started doing this so I replaced it. Within just two months (mayble three uses), now the new one will not get hot as well... I am quite upset
Posted on Jul 04, 2007
Same thing happened here, I have used the iron 5 times and now it does not heat up. I guess this thing is a piece of junk. It was made in china so I am not surprised!
Posted on Jul 04, 2008
Canon mx320 printer error has occurred 5200
You need to reset the printer. Try the steps:
• Plug in the power cord of printer.
Press Resume button 2 seconds
then press the power button until the green light on (when pressing the power button,Resume button)
• Then release the resume button, but do not release the power button.
• While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
• Release both buttons simultaneously.
• Led will blink briefly and then will glow green.
• And the computer will detect new hardware, just ignore ...
• Press the power button again then the printer will flash and. Printer is ready for use.
Feb 06, 2013 | Canon PIXMA Office Equipment & Supplies
Print error 5200 on 340 canon
Hello!!! How are you.
www.smoothprinterservice.com
Dec 16, 2012 | Canon PIXMA MX340 Wireless Office...
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Waffle iron light goes on gut does not heat up
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle plates stop heating
Apr 09, 2010 | Waring WMK300 Professional Belgian Waffle...
Model no. wmk300 power Light comes on but it
just fixed mine with info found on hear. If you're a little handy or have someone who is it's a simple fix. Under bottom plate a thermal fuse is connected in black wire under white insulation. I picked one up at radio shack (http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal%20fuse&origkw=thermal%20fuse&sr=1) got the 228 dgree C. I **** insulation and removed. I then cut black wire at connection at each side. I then placed new fuse in line and crimped small connectors on each side. Placed insulation back on and taped up. Screwed back together and it worked fine. Fuse cost $1.69. To think I almost tossed it.
Jan 20, 2010 | Waring WMK300 Professional Belgian Waffle...
Car wont start diesel engine Could it be the 'glow plug'? what is a glow plug? how can i test?
A glow plug is a small heating element in the cylinder. It heats the diesel so that starting can be made easy. Is your car standing in the open frozen parking If yes, then it would require a lot of battery power to first heat all the cylinders and then turn the engine to start. What we do in such conditions is to light up some fire under the car and heat the fuel system enough for the diesel to warm up a little and thus save the battery for glow plugs. Generally, all vehicles have an indicator light which comes on when the glow plugs are ready for starting. The diesel will ignite on compression, but it has to reach the cylinder and thus has to be flowing. In cold it freezes and hence the need for glow plugs and the heat. If it is parked in heated parking then the need for glow plugs decreases.
Jan 01, 2010 | 1991 Peugeot 405
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
No heat
It will initialy take some time to heat, but if it doesnt become hot in 3min or so.. then make sure voltage is properly fed and also check for any switches or reset button. If all this doesnt work then it means the heating coil inside wud have been cut or fused.
Thankyou
Feb 10, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
613 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Ps Daengr
Ps Daengr
Level 1 Expert
bradyrock325
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
