Question about Zanussi ZWD1470W Front Load Washer / Dryer
The drum has started making a noise an appears to be free-er than usual
I suspect that the drum bearing is faulty - would you agree? . If it is the bearing, would I be able to replace it myself (I am fairly handy) or it it a task for the experts? If you think a DIY job is possible where is the best place to get a drum bearing from? The machine is a washer dryer - Zanussi/Electrolux ZWD1470W. Many Thanks in advance for your help.
Kerin
  • Zanussi Master
  • 3,463 Answers
Remove top cover and look at outer drum, if it is plastic, then it is a complete stripdown of m/c, not recommended unless you really know what you are doing.
If it is a metal outer drum, then it can be done from rear of washer, without too much hassle.
If you are in the u/k, and you need spares, then go to,
www.seviceforce.co.uk
Plz rate my solution.
Tghanks.
Posted on Jan 21, 2009
Loud Bearing Noise During Spin Cycle- MAH4000AWW
I don't know these front loaders so well but, here's a couple of things to look for.
1) If belt driven, look for the spring loaded tensioner. Once tension is released, check the pully & see if it has excessive play.
2) Check the gasket on front panel & see if drum has rubbed thru it in order to make metal to metal contact.
3) There is alot of pressure on that rear bearing...make sure it's not egg shaped or scored on the inside.
If all else fails, shotgun it (in other words, replace those moving parts you suspect:)
Nov 15, 2013 | Maytag Washing Machines
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
My washer has started making a high-pitched noise while spinning.
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
My Frigidaire heavy duty dryer stopped working. It has worked fine for 15 years. Now when I push the START button it makes a noise but does not start as usual.
The loud noise could be a faulty or worn out motor. Or if the motor is good, the drum bearings might be worn and motor cannot turn drum. You will most likely have to remove some access panels to get a closer look at where the sound is coming from. There is excellent videos and information on howstuffworks.com that will explain the workings of a dryer and troubleshooting and more.
But please feel free to ask any other questions you may have.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Rear drum bearing
When it is like that you usually need to replace the drum bearing.
Ifthe tub recently started making a lot of noise, and you can feel thatthe bearing had too much play when spinning by hand, that means thatthe drum bearing needed to be replaced.
You can find the replacement part and the schematics here.
See also :
Mar 07, 2009 | Hotpoint NWXR473EV Dryer
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Makes growling noise when first started, quits once warm.
suspect noise from motor repair cost may exceed value but may want to ck rear drum bearing also this will mean pulling tub out bearing is on rear drum shaft not a hard fix but will need some mechanical know how ..good luck
Nov 13, 2008 | GE Dryers
Zanussi ZWD1470W Front Load Washer / Dryer Logo
274 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
