JVC LT-26C31BJE LCD TV
It has three horizontal lines running from right side to about two thirds across. They are fuzzy and change colour depending what colour they cross, from dark grey to red.  my jvc lt-26c31bje lcd tv has dark branch like lines going from right to left. can it be repaired.
3 Suggested Answers
  • 187 Answers
SOURCE: hi how can I fix a JVC LT-26c31bje TV it doesn't
If you have the led light on or blinking just replace the mainboard, if you dont have any led light at all, then you need to replace the powerboard.
Posted on May 27, 2009
jdvillanueva
  • 2098 Answers
SOURCE: JVC TV, LT-26C31BJE Sound but no picture. Is it
Hi cross_keys,
Before thinking of a new set, try this first.
You may power on the unit in the dark room and directly shine the flashlight to the LCD monitor. You will barely see an image or picture because the fault is either the inverter board or the lamp (backlight). You may isolate the problem but it will require you some tools and test instruments. Also, you must know some basic safety precaution in electronics troubleshooting.
Best way to find the faulty parts between the two you need to test the output of the inverter board. You can do it using the voltmeter or if does not available you may substitute a two 12v car bulb in series to the output of the inverter board. Powering on the unit and look if the bulb will glow or not. Yes, your lamp was busted. No, the inverter board fail.
You may look online for the replacement of defective parts. http://shop.ebay.com/i.html?_nkw=LT-26C31BJE&_sacat=0&_odkw=42RV600E&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 02, 2011
Jvc lt 26da20j why does it suddenly stop and display several colourful lines and not turn off?
Sounds like T'Con fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 19, 2014 | Televison & Video
Jvc lt-42pm30
Horizontal lines are usually caused by a bad LCD (screen)..
Sep 24, 2017 | JVC LT-42X579 42 in. LCD TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
JVC LT-32DY8ZJ FUZZY PICTURE
Fixed my problem, took it back, got refund and bought a different telly !
Feb 29, 2008 | JVC Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
JVC LT-26DF7BK won't turn on
Hi I had the same problem with my LT-26C31BJE. The TV just stuck in standby mode. If you tried to turn it on, it seemed like it tried to power up, but then reverted back to standby.
I solved it this way. I took the back off the TV (unplugged of course) and made sure all visible contacts were home (they all seemed to be). Also to the right of where the power lead enters the box there is a small fuse, 250V 6.3 W. I replaced this fuse and the TV now works fine.
Dec 27, 2007 | Televison & Video
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
