Question about Frigidaire GLGQ2152ES Gas Dryer
Frigidaire stackable dryer fse446rhs2 makes a bumping noise
Makes a regular bumping noise, seems to come from the top, where I'm guessing the mechanics are located. I'm a single mom, not that experienced, but did fix my washer last year with only minimal damage to the ceiling in the room below!
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfghjhd
Posted on Sep 29, 2010
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
I can't find the thermal fuse on a fse446rhs2 electric model
Location is inside the cabinet on the back wall. Upper right hand corner by where the terminal block is. Mounts by 2 screws. Part number 134120900 .
Sep 15, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FSE446RHS2 electric dryer makes bumping noise when drying. Opened the top, belt is ok.
Rear bearing and drum coupler needs to be replaced
bearing kit part #WC5303281153 is available online from many parts stores. You may want to replace the belt at the same time while you have the unit apart. Also inspect the front upper drum felt if it is worn replace it. The whole repair time for me was about 45 minutes dryer now runs like new.
Jul 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer comes on for a few minutes, makes horrible sound and goes off. now won't start at all. Frigidaire stackable
It could be the belt was partially broken, and as it came apart causing the dryer to no longer start,,, it made the noise your talking about. If the dryer still heats up, and you can hear the motor running,,, these would all be signs toward a broken belt.
Mar 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLGQ2152ES Gas Dryer Logo
248 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
