Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Wd71 with e30 code on display when i try to use the dryer
I used the washer this morning and now im trying to dry my clothes but when i select dry full heat 60mins it starts up then starts beeping with e30 see user guide can you help plz x
  • 43 Answers
Try changing the thermostat located on top of heater in top of machine
Posted on Nov 12, 2008
I have a Maytag Epic z, electric. They dryer turns on but not heat
Instructions
Dryer
Examine the household fuses or circuit breakers if the unit is not working, as the Epic z dryer uses more than one circuit or fuse. Replace or reset as necessary. Use a power outlet with 240 volts or more, which you can determine with a volt meter.
Close the Epic z door firmly and press the "Power" button for at least one second if the dryer has power but isn't working. If there is no heat, verify that you selected a heat dry option.
Look inside the dryer for objects that may have fallen out of pockets if there is a clicking or thumping noise. Examine the drum edges and remove items if possible. Separate pieces of clothing inside the dryer if the items got tangled together, and reduce the load size if necessary.
Tighten the legs on the dryer if the unit is rocking side to side during use. All four legs should touch the floor evenly. Adjust as needed.
5
Press and hold "Start" if a "PF" (power failure) error code appears. If the code persists, press "Power" and then a new cycle selection.
6
Contact Maytag for help if an error code with an "E" and a number appears on the display.
Washer
7
Ensure the Epic z washing machine is plugged into a grounded three-prong outlet if it doesn't start. Shut the lid firmly and press a wash cycle before selecting "Start." Select "Start/Pause" if an error code appears on the display and unplug the unit for several minutes. Reconnect power and choose a new cycle before pressing "Start."
8
Verify that the hose connections are tight on both ends and only high-efficiency (HE) detergent is being used if the washer is leaking. Do not open the washer lid during the wash cycle, as water can deflect off items and splash out of the washing machine.
9
Select "Rinse and Drain/Spin" if the door does not unlock. This removes any excess water from the washer tub. If "Add a Garment" is illuminated, select "Start/Pause" to unlock the door.
10
Verify that you placed the correct detergent in the correct dispenser if the dispenser is clogged or is not dispensing as expected. Wipe out the dispenser drawer with a damp cloth and dry it before adding the correct detergent.
11
Leave the door open after use (if small children and/or pets are not present) if the washer smells badly. Place a laundry cleaning tablet, available at grocery and hardware stores, into the washer and set the washer to the highest temperature wash possible to clean the unit.
Both Units
12
Set a piece of 3/4-inch plywood under the washer or dryer (or both if stacked) if the machine is thumping or vibrating or the floor seems too weak to support the unit(s).
13
Tighten the feet on the unit and make sure all four feet are level on the ground if there is vibrating or thumping during use.
14
Do not connect the washer or dryer to an extension cord, as extension cords cannot supply the power necessary for the unit(s).
Jan 09, 2013 | Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a WD63 washer dryer and the thermal fuse keeps blowing, I have changed the fuse several times and it appeared to work initially if I just put it straight into drying mode but every time I do a wash...
The thermal fuse is blowing for a reason. Over temperature condition. Make sure the vent is unobstructed all the way out and not pinched off anywhere. If that is good then have the operatiing thermostat checked and the Hi Limit thermostat. Best case for this is to replace all of them as they can stick intermittently.
Jun 09, 2009 | Dryers
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
181 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
