Question about SanDisk Sansa c200 MP3 Player
Can not turn the Sandisk on...
I have had my player for about 3 months and all of the sudden I can not turn it on . It says that it is charged but it still won't turn on.
  • nikila23 Mar 17, 2009
    i have charged fully.but after that i whould like to hear the song it not respond.after along time it says battery low.i dont know how to charge it. plz tell the solution.
  • Anonymous Mar 22, 2009
    i have charged it fully but after that it was not working
  • 8,596 Answers
Make sure the lock switch is not engaged first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
I Was Just Listening To My Mp3 Player, Then The Song Stopped, And Froze, So I Turned the Switch Off, And Now It Wont Turn On. I Tried The Reset Button But That Didn't Work Either. My Mp3 Is One Of Those...
Leave it on charge for at least four hours.
See if it works.
If it has charged from that port on your computer before the port should be ok.
You could try a different port if you have one.
If no luck, try a different charging cable or charger if you have one.
Charging is discussed on page 7 of the manual.
www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
If it is only a month old, it may be under warranty.
Ask where you got it from, or contact Sandisk.
The page for the Sansa is here www.sandisk.com/products/sansa-music-and-video-players
Feb 01, 2011 | SanDisk Sansa e250 MP3 Player
I got a sansa fuze about 2 monthes ago and all the sudden it will not turn on what do i do?
Having received no response in over a month, I assume the suggested reset worked.
Jun 28, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa 2gb wont turn on
hold the volume button + - at the same time, and push the power switch up
Jun 12, 2008 | SanDisk Sansa Clip MP3 Player
SandisK MP3 player
Sounds like she has corrupted her player somehow...
Like computers, mp3 plyers need to be formatted just like the hard drives...her Player should have come with a CD...which will walk her through formatting her player so that it's usable again.
She will loose all that is on there now...but will be able to reload her music ..
Thank you
~~Jasta~~
Mar 30, 2008 | SanDisk Sansa e270 MP3 Player
My laser mp3 player
i have the same problem,
it turns on when i plug the usb cable in.
BUT IT DOESN'T HOLD THE CHARGE
grr.
What should i do?
It's only 3 months old and all of a sudden it's just gone flat and wont charge
Feb 16, 2008 | Audio Players & Recorders
Connection/ Transferring tracks problems with Rhapsody.
left it charging over night and all the music erased...
Nov 26, 2007 | SanDisk Sansa e250 MP3 Player
Please help
maby try pressing the very small re set button usulu at the side or back . You might nead to press it with a hair clip or pin it`s tiny
Apr 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
135 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
