Question about Samsung SCH-u740 Cellular Phone
Samsung alias reception problem
Plugged and external antenna into a samsung alias and now when the antenna is not plugged in there is no reception anymore no matter where the phone is.
4 Suggested Answers
SOURCE: Audio problems on my samsung alias phone
its the battery. same thing on my phone sometomes i flick the back of the battery casing and it seems to work.
Posted on Mar 24, 2009
VinayT
  • 1884 Answers
SOURCE: SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Posted on Aug 05, 2009
samuraix
  • 203 Answers
SOURCE: alias sch u740 bad reception
hey, make sure that the simcard that you are using is supported by your celphone, the one that they called openline means all networks or simcards can be use with it.
Posted on Sep 30, 2009
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
I have a problum with my nuvi 610/660 not recieving satellite signals?
I have repaired literally hundreds of the 6xx series units with reception issues. In most cases, the problem is caused by a defective part on the GPS receiver board, located in the flip-up GPS/Antenna assembly.
In many cases, reception can be restored by connecting an external antenna to the unit. The defective part causes the unit to only look for signals at the external antenna port. In some cases, the part may prevent reception with both the internal or external antenna. In this case, the part must be replaced. Firmware upgrades will NOT fix this problem. It is a hardware problem caused by an electrostatic discharge.
For more information about this problem and how to have it repaired, please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
SHARCNET-USA
Nov 04, 2010 | Garmin Nuvi 660 GPS Receiver
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Alias sch u740 bad reception
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
Awful AM reception on Sony ICF-CD513 kitchen radio
You may have to use foil or other metal to extend the antenna artificially. I found years ago that even wrapping my hand around the end of it boosted the signal (though I'm sure you're not willing to listen to a radio while holding the antenna the whole time). I once sat a TV antenna on top of a portable CRT with its own internal ferrite antenna, and the video signal was about 80% there, audio 100%. This may be an inconvenient method, but it will guarantee at least most of the audio quality you want.
Jan 30, 2018 | Sony ICF-CD555TV 7 in. Portable Television
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
Internal Antenna not working anymore
if you do a search at pdaphonehome.com a guy has replaced his antenna and provided step by step instructions for how to do it yourself with pictures. I don't know if frying it can make sure getting a new antenna will fix that but thats something you can try before replacing.
May 12, 2007 | Samsung SCH-i730 Pocket PC
Reception
While in the truck, make sure the antenna is on the outside of the truck. It has magnet so it is easy to stick to the roof. Do not know what to say about the home antenna, mine is not working right now.
Dec 14, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Samsung SCH-u740 Cellular Phone Logo
332 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
