Question about Panasonic Home Theater System System
Sony davs 500
My sony davs 500 has just gone dead.. No power at all no lights on. Took case off and internal fuse still ok.
  • jude35 Nov 09, 2008
    Hi again they is no lights on at all and the internal fuse that is still ok is F901
  • 10,594 Answers
Does its standby light lit?
Can you mention what fuse you checked and found OK. Please write fuse circuit number like F600, F201 etc
Posted on Nov 08, 2008
Sony DAV-FC7 won't power on. I bought it new and have only had it for about 2 years.
I suspect you might have a power failure caused by an internal fuse. Fuses rarely just go on their own, so it might be caused by an overload, generally caused by a faulty output device.
If you have any knowledge to repair one or no someone who has you can or they can look around inside. Otherwise it's off to the repair shop with it. Unless you have a five year warranty on it or have paid for extra cover, then you will be liable for the full cost of the repair. If you have a five year cover or extended plan, contact the manufactory or the service plan provider. But do NOT open the unit yourself.
Sep 25, 2016 | Sony DAV-FC7 System
CPU dead? Please help
check if power supply is ok and cable securely connected.
check if the power switch is ok - sometimes it takes several attempts to power on.
check if you can see green light inside the cpu.
when was the last time cpu worked?
Feb 24, 2014 | Sony DAV-S400 System
Andrea my sony dav-dz260 will not turn on , fuse in plug is ok small fuse on power board ok power all over three circut boards but will not light up
In this case what is required is a probe using a multimeter and you must be technically inclined to check this out. Please be careful not to short and unless you are confident to use a multimeter with the selected range to check for the Secondary LT voltages to the circuit , it is not recommended.
If you can get a tutorital on use of multimeter, you can start from the secondary power supply , check out each sections of the DC outputs to the respective board .
If power seems good then you need to know the basics of the block sections of the amplifier to proceed further so as to identify.
Oct 11, 2011 | Sony DAV-DZ260 Theater System
Getting an error display as "Push power protector" in my Sony Home theatre - DAV DZ777. what is the solution.
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Jan 21, 2011 | Sony DAV-DX255 System
My sony davis 10 ' push power prtector'
dead short. Check wiring inside case. Power Protect keeps it for catching fire or electrical shock. Tech Fix only in most cases.
Mar 08, 2010 | Sony DAV-IS10 System
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
Dead set no standby light power ok up to
Could be anything! From a main board to a power supply. I recommend getting service on it from a authorized sony service center. If standby light doesn't appear at all for any given time, then it maybe the power supply.
Jun 23, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
No power to player!?
Open it up and check the main fuse. It is located on the board where the wall plug enters the chassis.
Jan 19, 2008 | Sony DAV-S500 System
Sony DAV C450 No Power - Dead Unit
I am having this same problem. I have checked all fuses and all seem ok. Does anyone know what else might be keeping this from powering on? Any common problems that this one had to cause this? Also does anyone have a diagram of the schematics or the service manual?
Thanks in Advanced.
Jul 22, 2007 | Sony DAV-C450 System
Panasonic Home Theater System System Logo
111 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
