Question about GPX K1007 Boombox
Cd plus g disc for gpx k1007 karaoke party machine
Where do i get a cd plus g disc for gpx k1007 karaoke party machine?
SOURCE: Need GX CD+G Party Machine Karaoke Manual
go to the gpx website www.gpx.com
Posted on Dec 25, 2008
SOURCE: i just received a karaoke party machine gpx JM250s
Make sure you have the input, upper right of front, set to CD-G not CD.
Posted on Dec 25, 2010
  • 5603 Answers
SOURCE: I just received a GPX JM250S Karaoke Party
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Posted on Dec 27, 2010
  • 5603 Answers
SOURCE: we just bought a GPX
You MUST use a specially prepared Karaoke CD, not just a plain music CD.
Posted on Jan 18, 2011
  • 5603 Answers
SOURCE: Need A/C Power Cord for
A good place to find cords and also adapters is at Thrift Stores.
Posted on Jun 06, 2011
Can seem to view the lyrics on screen of my new gpx karaoke party machine, can you help me?
You MUST use SPECIAL Karaoke disks that have the lyrics... Is that what you are using?
Jun 26, 2011 | GPX Digital Products International Karaoke...
Daughter received a GPX JM250S Karaoke Party Machine for Christmas and can not get the lyrics to display. I have a CD-G and it is on that setting, but no lyrics.
From the FAQ for this unit:
Make sure that you are in either CDG or AUX mode and then adjust the BRIGHT, CONTRAST, AND V-HOLD knobs, on the back of the unit, if needed
Dec 31, 2010 | Digital Products International Karaoke...
My machine will not play disc will just read out no disc
Either the laser lens eye is dirty and needs to be cleaned with rubbing alcohol and a cotton swab, or if the cleaning doesn't help, then the laser lens circuit may need to be replaced.
Mar 19, 2010 | GPX Karaoke Party Machine CD+G Portable...
My machine does not ready the Cd that i put in
1st - ensure your disc is of a compatable format with your Karaoke unit.
2nd - check the disc for dirty or scratched surface. Rectify disc surface as neccessary.
3rd - Have the Optical Lens (sometimes called the optical laser) cleaned
4th - depending on unit's age, the optical lens may be losing its ability to read different wavelengths, hence might read one type of disc, but not another.
Cheers,
"If this has helped you in any way, please rate this solution" :-)
Jan 27, 2010 | GPX Karaoke Party Machine CD+G Portable...
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
My daughter touched the lens can it be replaced
Is the lens broken or does the player still read discs? If it is broken, sadly, you would have to either replace the whole transport (a real hassle), or purchase a new machine.
Hope this solves your problem,
Hortona
Mar 25, 2009 | GPX Karaoke Party Machine CD+G Portable...
GPX K1007 Boombox Logo
192 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
