Question about AEG Santo 3888 KG8 Bottom Freezer Refrigerator
What does the flashing (warning?) light mean
Hi I was just changing the temperature setting on the refridgerator. Then afterwards the warning light starting flashing and there was a loud beep. I pressed the warning? light (the light on the far right) and the sound stopped, but the light is still flashing. What does this mean? What should I do.
  • Matthew Findley Oct 22, 2006
    Just to clarify this is for model 4088-8 kg...thanks
Defrost it all or try turning off by mains then on at a later time.
Posted on Jun 15, 2008
Can anyone assist with an English manual for the Santo S 75398 KG3.
Much appreciated
Posted on Nov 30, 2007
Problem is only automatic warniong for temperature change, e.g you left your fridge open. press the button and leave the fridge.
Posted on Jul 11, 2007
  • 237 Answers
Did you ever get any advice for this problem? Please repost if not.
Posted on Dec 23, 2006
SOURCE:
2014 Gilera Runner ST 125 temperature gauge keeps flashing
Hi, Anonymous and the usual suspects are:
1. Grounded temperature light/gauge circuit.
2. Faulty thermostat temperature sensor.
3. Faulty cylinder head heat sensor.
4. Faulty thermostat.
5. Faulty light or gauge.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.apriliaforum.com/forums/showthread.php?277723-warning-light-coming-on-and-temp-guage-icon-flashing
gilera runner over heating problems
Gilera Runner 50 1997 Service And Repair Manual
Gilera RUNNER VX VXR 125 200 125 2003 Parts
http://www.bellamoto.rs/upl/files/Runner%20ST%20125%20-%20200%20UPUTSTVO.pdf free owners manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 18, 2018 | 2011 Gilera Runner ST 125
Hi, I just changed a Power Supply(PSU1) and now
got the same Problem yesterday .. did u fixed it ?
Sep 23, 2013 | Enhance Technology Ultrastor RS16SS
Check engine oil light flashes after oil change
Do you mean oil change warning light or oil pressure warning light?
Feb 04, 2013 | 1999 Volkswagen Jetta
Jetta Warning Light
It says that your vehicle is low on coolant.Get the coolant level checked.If low has to be changed.
------------Check out few help links related to your issue.Click the link below:---
Service 4wd warning light on Dash? http://howtobyme.blogspot.com/2011/11/service-4wd-warning-light-on-dash.html
Car Turns OFF due to low oil pressure warning light? http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Hybrid warning Light ON? http://whatisbyme.blogspot.in/2012/05/2005-toyota-prius-hybrid-warning-light.html
Order Coolant Bypass Tube? http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
Coolant Leak? http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
COOLANT LEAK AT DRIVER SIDE NEAR FIREWALL? http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together? http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
Engine Coolant Temperature (ECT) Sensor Replacing? http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html Loosing Coolant? http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
---------- Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
----------- Where to Add Coolant? http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
------------ Blue Water Warning Light on Dash? http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Oct 09, 2012 | 1995 Volkswagen Jetta
The red warning light is flashing after freezer being moved
This will happen until the temperature gets down to an acceptable temperature.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Freezers
HOT TRANSMISSION LIGHT FLASHING
When this warning light flashes it means the fluid (ATF) temperature of the transmission have reached a level that is detrimental to the operation of the transmission and damage will occur if the cause is not corrected. The causes can be overloading (towing) the vehicle, severe operational circumstances such as high air temps. Other common causes are excessive slippage of the transmission due to worn clutch packs or a defective torque converter. Also the TFT (trans fluid temperature sensor) can malfunction and send a false signal to transmission control module (TCM) and set the warning light. I would not ignore this warning, have it checked by a transmission shop or the dealer.
Jan 05, 2012 | Hummer H2 Cars & Trucks
My display keeps shutting off five minutes after starting to watch TV- the sound continues, but the screen is black and the red warning light flashes
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
Thanx
Jul 02, 2010 | Fujitsu Plasmavision 42" TV
Blue light started flashing what is wrong
Hi, has the weather just turned colder? The Beetle has a blue warning light to tell you that the engine temperature is low. Meaning drive the car at lower speeds/revs until it's warmed up and the light go's out. Hope that helps, Matt.
Nov 21, 2009 | 2000 Volkswagen Beetle
High temp warning
2 BLINKS: Temperature
Apr 05, 2008 | Sony KDS-R50XBR1 50" HDTV
AEG Santo 3888 KG8 Bottom Freezer Refrigerator Logo
2,238 people viewed this question
Top AEG Refrigerators Experts
Tony
Level 1 Expert
David Del Polito
David Del Polito
Level 1 Expert
Steve F
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
