Question about Panasonic Lumix DMC-FZ20 Digital Camera
Please turn camera off and then on again
That is message on camera and turn off and on again...nothing happens...can view pictures on memory card, but cannot take new pics
  • Ronald Zdan
    Ronald Zdan Dec 09, 2008
    I have been having a problem with my FZ20. Periodically I get the
    message on the screen "please turn camera off and then on again"
    Sometimes this occurs repeatedly and I miss the opportunity to take
    pictures. Why is this happening and what needs to be done to fix this
    problem? Any help would be greatly appreciated, thanks.
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Posted on Dec 27, 2007
RadarRon
  • 398 Answers
SOURCE: Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Posted on Feb 12, 2008
SOURCE: Sony Cybershot DSC-W90
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Posted on May 05, 2008
  • 3 Answers
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Posted on May 21, 2008
yvonmagic
  • 82 Answers
SOURCE: unable to view pics from memory card of lumix camera
hi i think your memory card is dead, just to make sure try it in something else. let me know Yvon chow !!!
Posted on Jan 02, 2009
When I turn my camera on to view pictures, the red light on the camera in the bottom right corner stays on and I'm not able to view my pictures on my memory card. Can you help me identify the problem?
If one card works and the other doesn't then it sounds like you have a defective SD card. Nothing you can do about this but buy another one and toss it.
This is why you should backup all your photos off the camera and onto permanent storage media.
Sep 29, 2014 | Canon EOS Rebel XSi Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Keep getting message to reinsert memory stick!!!! Help!!!
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 16, 2009 | Cameras
I have this message on my sony digital camera:"REINSERT THE MEMORY STICK" why?
Oct 10, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
Will not allow me to view pictures I just took
Try to recover what is left on the memory stick with TestDisk on a pc.
Note, download the windows version and not the dos/windows version, the
dos/windows version is for windows 3.11 and lower.
http://www.cgsecurity.org/wiki/TestDisk_Download
Try to fomat the card afterwards if this does'nt help at all try another card in
your camera, if the other card works replace your other card else get te camera autorized repairs man.
Succes.
Aug 28, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick.And there is nothing in the manual about how to fix it. When I turn on my camera I get an error...
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
Apr 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 02, 2009 | Olympus Stylus 790SW Digital Camera
Incompatible JPEG format
right click on one image on the computer >> properties >>open with >> choose windows picture and fax viewer >>click ok
Jul 17, 2008 | Canon PowerShot A540 Digital Camera
I have a Nikon N65 camera not digital.
If you take the battery its okey there nothing happens to your 23 pictures it remained in the memory card and if you doubt it transfer it to your PC for safety .Then do the the procedure ive said above by taking the battery .Start the camera without a memory card inside and go to view picture ,see if the FEE still there ..
please rate the solution as FIXYA if this helps you solving your problem...
Jun 24, 2008 | Cameras
Panasonic Lumix DMC-FZ20 Digital Camera Logo
48 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
